memory leaks in BCGSL when using KSPReset()
After adding this test in petsc4py-dev/test/test_ksp.py : def testResetAndSolve(self): self.ksp.reset() self.testSolve() self.ksp.reset() self.testSolve() self.ksp.reset() it seems there is some memory bleeding: [0]Total space allocated 256 bytes [ 0]80 bytes KSPSetUp_BCGSL() line 476 in /home/devel/petsc/dev/src/ksp/ksp/impls/bcgsl/bcgsl.c [0] KSPSetUp() line 184 in /home/devel/petsc/dev/src/ksp/ksp/interface/itfunc.c [0] KSPSolve() line 332 in /home/devel/petsc/dev/src/ksp/ksp/interface/itfunc.c These are workspace arrays that are re-allocated at every KSPSetup_BCGSL call. Not sure about the proper way to fix this, but I would deallocate the arrays at KSPReset_BCGSL. Can anyone help me with this? PS: Will we ever have petsc4py in the nightly builds? Is there something to be done from my side? -- Lisandro Dalcin --------------- CIMEC (INTEC/CONICET-UNL) Predio CONICET-Santa Fe Colectora RN 168 Km 472, Paraje El Pozo 3000 Santa Fe, Argentina Tel: +54-342-4511594 (ext 1011) Tel/Fax: +54-342-4511169
participants (1)
Lisandro Dalcin
