Yep, we found these. I am going to make a PR. Thanks for reporting. Matt On Fri, Dec 14, 2018 at 9:17 PM Eric Chamberland via petsc-dev < [email protected]> wrote:
I just noticed there are warnings at compile time for some mkl_cpardiso.c routines:
/pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/impls/aij/mpi/mkl_cpardiso/mkl_cpardiso.c: In function ‘MatDestroy_MKL_CPARDISO’: /pmi/cmpbib/compilation_BIB_gcc_redhat_petsc-master_debug/COMPILE_AUTO/petsc-master-debug/src/mat/impls/aij/mpi/mkl_cpardiso/mkl_cpardiso.c:236:7: warning: passing argument 16 of ‘cluster_sparse_solver’ from incompatible pointer type [enabled by default] (int*)&mat_mkl_cpardiso->err);
and some more, full log here:
http://www.giref.ulaval.ca/~cmpgiref/petsc-master-debug/2018.12.14.09h24m33s...
and configure log:
Eric
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
participants (1)
Matthew Knepley
