Re: [petsc-dev] Figures 20, 21 in Chapter 13.1 of PETSc manual are out of date
Hi, Patrick, It is great if you can update it. I am still learning PETSc and the manual. BTW, I found ex10.c contains out-of-date comments, which were there for the profiling manual, but the code diverged from the comments. Maybe you can create a new test for the manual and add comments saying the test is for the manual so that one will not accidentally overwrite it. --Junchao Zhang On Thu, Apr 19, 2018 at 1:01 AM, Patrick Sanan <[email protected]> wrote:
Sorry I didn't catch this when cleaning up the manual recently. If you don't have time to update it yourself, let me know and I will.
2018-04-19 5:23 GMT+02:00 Karl Rupp <[email protected]>:
Hi Junchao,
1) The manual says the example is src/ksp/ksp/examples/ex10.c, but it
actually links to src/ksp/ksp/examples/tutorial/ex10.c. This is a minor issue. 2) One could not use the same command line options (-f0 medium -f1 arco6) as shown in the figures. There are no such matrices so one can't simply copy & paste. 3) It seems ex10.c had gone through large changes and it can not produce a log summary similar to the figures anymore (e.g., no stages like "Event Stage 4: KSPSetUp 1" ).
such things (unfortunately) tend to happen over time. Please feel free to fix it :-)
Best regards, Karli
participants (1)
Junchao Zhang
