Re: [petsc-dev] Compiling error with Hypre-2.11.2
How come we don't have version checks as a matter of course for config/packages/xxx.py we constantly get email from people using the wrong version of external packages with obscure error messages wasting their time and hours. Better that hypre.py (and others) compare the version number and exit with a nice error message when incompatible. Barry We could have a field called say supportedversions = ['version1', 'version2',....]
On Aug 2, 2018, at 11:50 AM, Satish Balay <[email protected]> wrote:
https://bitbucket.org/petsc/petsc/commits/e6de09342ce9c4562cc062ff2c1bac4bd9...
It is compatible with Hypre-2.14. For Hypre-2.11 - you would have to revert the above change.
Satish
On Thu, 2 Aug 2018, Antonio Trande wrote:
Hi all.
Petsc-3.9.3 does not compile against Hypre-2.11.2:
mpicc -c -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -O2 -g -pipe -Wall -Wp,-D_FORTIFY_SOURCE=2 -fexceptions -fstack-protector-strong --param=ssp-buffer-size=4 -grecord-gcc-switches -m64 -mtune=generic -O3 -Wl,-z,now -fPIC -I/builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/include -I/builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/x86_64/include -I/usr/include/openmpi-x86_64 -I/usr/include/openmpi-x86_64/hypre -MMD -MP /builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/src/mat/impls/composite/mcomposite.c -o x86_64/obj/mat/impls/composite/mcomposite.o /builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/src/mat/impls/hypre/mhypre.c: In function 'hypre_array_destroy': /builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/src/mat/impls/hypre/mhypre.c:1453:37: error: macro "hypre_TFree" passed 2 arguments, but takes just 1 hypre_TFree(ptr,HYPRE_MEMORY_HOST); ^ /builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/src/mat/impls/hypre/mhypre.c:1453:4: error: 'hypre_TFree' undeclared (first use in this function) hypre_TFree(ptr,HYPRE_MEMORY_HOST); ^ /builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir/src/mat/impls/hypre/mhypre.c:1453:4: note: each undeclared identifier is reported only once for each function it appears in gmake[2]: *** [x86_64/obj/mat/impls/hypre/mhypre.o] Error 1 gmake[2]: *** Waiting for unfinished jobs.... gmake[2]: Leaving directory `/builddir/build/BUILD/petsc-3.9.3/buildopenmpi_dir'
Full build log: https://koji.fedoraproject.org/koji/getfile?taskID=28789567&volume=DEFAULT&n...
Dependencies list: https://kojipkgs.fedoraproject.org//work/tasks/9567/28789567/root.log
participants (1)
Smith, Barry F.
