Re: [petsc-dev] MatNest in petsc4py with empty submatrices
On 17/02/16 14:47, Chris Eldred wrote:
Hey All,
I was wondering if anyone had used MatNest with petsc4py. I am having issues trying to create a MatNest where some of the submatrices are empty. In PETSc, I can just pass NULL in the array that I give to MatCreateNest and it works fine. However, the following code
We use it, but haven't used it with empty slots.
nest_list = [[None,None],[None,None]] nest_list[0][0] = some matrix nest_list[0][1] = some matrix nest_list[1][0] = some matrix A = PETSc.Mat().createNest(nest_list,comm=PETSc.COMM_WORLD)
fails with: File "Mat.pyx", line 445, in petsc4py.PETSc.Mat.createNest (src/petsc4py.PETSc.c:103202) TypeError: Cannot convert NoneType to petsc4py.PETSc.Mat
Is there an equivalent to NULL in petsc4py (there doesn't appear to be one)?
If all of the entries in nest_list are filled, everything works fine.
Any help would be appreciated!
Maybe a patch like this to petsc4py? diff --git a/src/PETSc/Mat.pyx b/src/PETSc/Mat.pyx index f281ba0..490c58e 100644 --- a/src/PETSc/Mat.pyx +++ b/src/PETSc/Mat.pyx @@ -460,7 +460,10 @@ cdef class Mat(Object): tmp1 = oarray_p(empty_p(nr*nc), NULL, <void**>&cmats) for i from 0 <= i < mr: for j from 0 <= j < mc: - cmats[i*mc+j] = (<Mat?>mats[i][j]).mat + if mats[i][j] is None: + cmats[i*mc+j] = NULL + else: + cmats[i*mc+j] = (<Mat?>mats[i][j]).mat if isrows is not None: tmp2 = oarray_p(empty_p(nr), NULL, <void**>&cisrows) for i from 0 <= i < mr: cisrows[i] = (<IS?>isrows[i]).iset Untested. If you want to pass null isrows and iscols as well you'll need to do a similar thing there. Cheers, Lawrence
participants (1)
Lawrence Mitchell
