Re: [petsc-dev] Performance of VecMDot_SeqCUSP
On Tue, Apr 24, 2012 at 11:55, Jose E. Roman <[email protected]> wrote:
It seems that VecMDot_SeqCUSP has rather poor performance. This has a lot of impact in SLEPc because it is the main kernel used in the orthogonalization of vectors.
Is this due to the version of Thrust? I am using CUDA Toolkit 4.0.
I tried a naive replacement that copies the contents of the vectors into a matrix and calls CUBLAS dgemv. The improvement is significant, despite the data movement overhead. In some tests I see a reduction of time (VecReduceArith) from 24.5 seconds to 9.6 seconds (with up to 200 vectors of length 10000) on a Fermi.
I can send the code for you to try.
That would be useful. The current code is horribly over-synchronous since it spawns a new kernel for each set of 3 vectors. We want to use one kernel to process all vectors. Unless there is another implementation somewhere, we'll probably want to write custom CUDA kernel for this (to avoid needing to copy all the vectors into contiguous memory).
participants (1)
Jed Brown
