Re: [petsc-dev] dates of last change on PETSc web pages
Do you have to manually change each web page? Hence they get committed with the current date? If change one file in hg in a week will it get the date when I made that change while the rest will have today's date?
For this update, yes, every page must be modified since we aren't doing any fancy javascript / server-side programming (yet?). If you modify a file a week from now, it will be that date once the website is regenerated. I'm planning on putting this date generation in a script that runs in the 'update-web' rule unless there is a better rule? Note, if we used some kind of server-side programming, one could argue it could be automatically (with less html code) but the cons of that would be 1) requiring more software on the server, and 2) learning a new programming model. FYI, the date generation could be done in javascript if someone wrote a parser for urls of the form: http://petsc.cs.iit.edu/petsc/petsc-dev/file/tip/src/docs/website
This is fine if this is the case. Otherwise ....
participants (1)
Sean Farley
