On Wed, 17 Sep 2008, Lisandro Dalcin wrote:
BTW, perhaps you should do the same in TSGetKSP(). What do you think?
Yes. It is pushed to petsc-dev. Hong
2008/9/17 Hong Zhang <[email protected]>:
TSGetSNES() must be called after TSSetType(), otherwise the nonlinear context 'snes' is being created. Attached please find updated ex7.c, which illustrates how to set uer-defined SNESMonitor().
This example is pushed to petsc-dev. I also added an error flag in petsc-dev to prevent calling of TSGetSNES() before TSSetType(). Thanks for reporting the problem!
Best,
Hong
On Fri, 12 Sep 2008, tsjb00 wrote:
Many thanks for your reply! The code I tried was very similar to the code in: ts/examples/tutorials/ex7.c except that I changed the r.h.s. function.
The code related to TS: ierr = TSCreate(PETSC_COMM_WORLD,&ts);CHKERRQ(ierr); ierr = TSSetProblemType(ts,TS_NONLINEAR);CHKERRQ(ierr); ierr = TSSetRHSFunction(ts,FormFunction,&appctx);CHKERRQ(ierr);
ierr = DAGetColoring(appctx.da,IS_COLORING_GLOBAL,&iscoloring);CHKERRQ(ierr); ierr = MatFDColoringCreate(J,iscoloring,&matfdcoloring);CHKERRQ(ierr); ierr = ISColoringDestroy(iscoloring);CHKERRQ(ierr); ierr = MatFDColoringSetFunction(matfdcoloring,(PetscErrorCode (*)(void))FormFunction,&appctx);CHKERRQ(ierr); ierr = MatFDColoringSetFromOptions(matfdcoloring);CHKERRQ(ierr); ierr = TSSetRHSJacobian(ts,J,J,TSDefaultComputeJacobianColor,matfdcoloring);CHKERRQ(ierr);
dt = appctx.dtmin; ierr = TSSetInitialTimeStep(ts,0.0,dt);CHKERRQ(ierr); ierr = TSSetType(ts,TS_BEULER);CHKERRQ(ierr);
Then I tried to add the snes monitor: PetscViewerASCIIOpen(PETSC_COMM_WORLD,"snes.log",&rviewer); ierr = TSGetSNES(ts,&ts_snes); ierr = SNESMonitorSet(ts_snes,SNESMonitorDefault,&rviewer,PETSC_NULL); I got the snes.log with long lines which started with countless blank/space and ended at the very end with the SNES iteration info. As a result, the file took a lot of memory space even with one line of outputs.
Please let me know if I did something wrong.
Have a nice weekend!
_________________________________________________________________ �°��ֻ�MSN�������������μ�������������ȡ��ɫ��Ʒ�� http://mobile.msn.com.cn/
-- Lisandro Dalc��n --------------- Centro Internacional de M��todos Computacionales en Ingenier��a (CIMEC) Instituto de Desarrollo Tecnol��gico para la Industria Qu��mica (INTEC) Consejo Nacional de Investigaciones Cient��ficas y T��cnicas (CONICET) PTLC - G��emes 3450, (3000) Santa Fe, Argentina Tel/Fax: +54-(0)342-451.1594
participants (1)
Hong Zhang
