Re: [petsc-dev] [petsc-maint #129715] __float128 complex
24 Aug
24 Aug
'12
10:55 a.m.
On 24.08.2012 17:53, Jose E. Roman wrote:
I guess PETSC_SCALAR should be correctly defined for the case complex+__float128 in petscsys.h. Maybe a new PetscDataType PETSC___COMPLEX128? This would require changing PetscMPIDataTypeToPetscDataType and then PetscBinaryRead...
It is better if someone else can be in charge of this change.
It is not necessary, I can write a kind of convertor myself. Otherwise complex128 seems to be working. -- Regards, Alexander
5103
Age (days ago)
5103
Last active (days ago)
0 comments
1 participants
participants (1)
Alexander Grayver
