Re: [petsc-dev] Faulty logic in MatHYPRESetPreallocation?
Barry, Probably this is an oversight from me. When I coded the MATHYPRE class, I did not make much attention to the preallocation. Also, hypre did not seem very robust to matrix reusage at the time. Take a look at the comments at line 85 in ex115 from mat tests. Probably Pierre's fix will curate that problem too. Stefano Il giorno Sab 22 Dic 2018, 06:30 Smith, Barry F. <[email protected]> ha scritto:
Stefeno,
Doe this look right to you?
Thanks
Barry
On Dec 17, 2018, at 3:18 AM, Pierre Jolivet via petsc-dev < [email protected]> wrote:
Hello, I am not sure the hypre routines are called in the right order in MatHYPRESetPreallocation. Indeed, attached, you’ll find two Massif logs, one with the current order (massif.out.bad), and the other (massif.out.better) with the attached patch applied. In the former, you can see at the snapshot #31 that there is a call to hypre_CTAlloc in hypre_AuxParCSRMatrixInitialize (aux_parcsr_matrix.c:163). This means that hypre is allocating memory as if it was not aware of the number of nonzero per row, even though I supply in my application the two arrays dnnz and onnz.
Am I missing something?
Thanks, Pierre
<massif.out.bad><massif.out.better><patch-hypre.txt>
participants (1)
Stefano Zampini
