Re: [petsc-dev] Generality of VecScatter
On Fri, Nov 25, 2011 at 20:06, Mark F. Adams <[email protected]>wrote:
MIS is straightforward. To define the parallel graph, let's say that ghosting processes have (owner rank, index) of neighbors. An owned point is only a candidate for selection if all neighbors have the same rank or smaller (according to Rule 2 of your paper).
while (candidates remain): forall v in owned_candidates with neighbor ranks smaller than p:
This is not quite right, and I want to see how complex or cumbersome this one sided model will get when you get all the details in.
You could say loop:
for all owned_candidates v for all neighbors q of v if q is selected delete v skip v else if q.proc > myproc and q is not deleted skip v endif end for if not skip v then select v delete all q broadcast v status ????
Why broadcast the single value immediately? I figured that we would just store the status until we are done with what we can do locally, then we'll do reduce-and-broadcast and move on to the next round.
endif end for reduce all status to owners ???
Yeah, we reduce the status from the local spaces (which may have marked a point as deleted), then broadcast. The communication graph is stored on the local side.
I thought in your one-sided model you could not broadcast, or push data. You can only pull data and only want to pull data. But you have a broadcast???
Remember that my first primitive was "broadcast", which is essentially global-to-local. The map is as a local-to-global map and the "get" is initiated at the local space.
participants (1)
Jed Brown
