Re: [petsc-dev] MatMatMult gives different results
Dear Hong, You can get matrices here: http://dl.dropbox.com/u/60982984/A.dat http://dl.dropbox.com/u/60982984/B.dat I wrote simple testing application for that problem (it looks ugly, but allows to reproduce the problem): Mat A,AT,B,C; PetscInt M,N; PetscInitialize(&argc,&args,(char *)0,help); ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD,"A.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr); ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr); ierr = MatSetType(A,MATMPIAIJ);CHKERRQ(ierr); ierr = MatLoad(A,viewer);CHKERRQ(ierr); ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr); ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD,"B.dat",FILE_MODE_READ,&viewer);CHKERRQ(ierr); ierr = MatCreate(PETSC_COMM_WORLD,&B);CHKERRQ(ierr); ierr = MatSetType(B,MATMPIDENSE);CHKERRQ(ierr); ierr = MatLoad(B,viewer);CHKERRQ(ierr); ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr); MatGetSize(A,&M,&N); MatCreateMPIAIJ(PETSC_COMM_WORLD, PETSC_DECIDE, PETSC_DECIDE, N, M, 12, PETSC_NULL, 12, PETSC_NULL, &AT); MatTranspose(A,MAT_IGNORE_MATRIX,&AT); MatMatMult(AT,B,MAT_INITIAL_MATRIX,PETSC_DEFAULT,&C); ierr = PetscViewerBinaryOpen(PETSC_COMM_WORLD,"C.dat",FILE_MODE_WRITE,&viewer);CHKERRQ(ierr); ierr = PetscViewerSetFormat(viewer,PETSC_VIEWER_NATIVE);CHKERRQ(ierr); ierr = MatView(C,viewer);CHKERRQ(ierr); ierr = PetscViewerDestroy(&viewer);CHKERRQ(ierr); ierr = PetscFinalize(); return 0; To compare results I use following Matlab script: A = PetscBinaryRead('A.dat','complex',true); B = PetscBinaryRead('B.dat','complex',true); Cm = A.'*B; C = PetscBinaryRead('C.dat','complex',true); Matrix C is different depending on number of cores I use. My PETSc is: Using Petsc Development HG revision: 876c894d95f4fa6561d0a91310ca914592527960 HG Date: Tue Jan 10 19:27:14 2012 +0100 On 06.02.2012 17:13, Hong Zhang wrote:
MatMatMult() in petsc is not well-tested for complex - could be buggy. Can you send us the matrices A and B in petsc binary format for investigation?
Hong
On Mon, Feb 6, 2012 at 5:55 AM, Alexander Grayver <[email protected] <mailto:[email protected]>> wrote:
Dear PETSc team,
I try to use: call MatMatMult(A,B,MAT_INITIAL_MATRIX,PETSC_DEFAULT_DOUBLE_PRECISION,C,ierr);CHKERRQ(ierr)
Where both A and B are rectangular, but A is sparse and B is dense. Both are double complex and distributed. The product PETSc gives me contains some errors in some part of the matrix. I output A, B and C then computed product in matlab.
Attached you see figure plotted as: imagesc(log10(abs(C-Cm)))
Where Cm -- product computed in matlab.
The pattern and amplitude vary depending on the number of cores I use. This picture is obtained for 48 cores (I've tried 12, 64 cores as well).
Where should I look for possible explanation?
-- Regards, Alexander
participants (1)
Alexander Grayver
