Re: [petsc-dev] BuildSystem clean-up
The assumption was that each external package had an appropriate clean that would be called by the XXXX.py BEFORE doing a build to clean it up; this did require each XXXX.py knowing how to call the clean and doing this. Clearly this assumption was wilding optimistic.
Way too optimistic.
The draw back to having buildsystem (note the lack of caps) doing the clean AFTER doing the building is important generated stuff useful for debugging may be lost. So what about doing the clean out of that directory at the beginning, not at the end?
Actually, I was advocating cleaning it out at the beginning but in packages.py it doesn't seem easy to tell if self.installNeeded is set yet. Do we just blindly blow away this directory? Or should we (Matt) define a preInstall concept? How buildsystem knowns if the package should be rebuilt is NOT stored in
that directory so making your change should not affect the current somewhat "smart" build again only if needed logic.
Righto.
participants (1)
Sean Farley
