Re: [petsc-dev] PETSc GPU example
On Mon, Dec 6, 2021 at 7:54 PM Fande Kong <[email protected]> wrote:
Thanks, Matt,
Sorry, I still have more questions on this example. How to refine mesh to make the problem larger?
I tried the following options, and none of them worked. I might do something wrong.
-ex56_dm_refine 9
and
-dm_refine 4
The mesh handling in this example does not conform to the others, but it appears that -ex56_dm_refine <k> should take effect at https://gitlab.com/petsc/petsc/-/blob/main/src/snes/tutorials/ex56.c#L381 unless you are setting max_conv_its to 0 somehow. Thanks, Matt
Fande
On Mon, Dec 6, 2021 at 5:04 PM Matthew Knepley <[email protected]> wrote:
On Mon, Dec 6, 2021 at 7:02 PM Fande Kong <[email protected]> wrote:
Thanks, Matt
On Mon, Dec 6, 2021 at 4:47 PM Matthew Knepley <[email protected]> wrote:
On Mon, Dec 6, 2021 at 6:40 PM Fande Kong <[email protected]> wrote:
Dear PETSc team,
I am interested in a careful evaluation of PETSc GPU performance in our INL cluster.
Any example in PETSc that can show GPU speedup with solving a nonlinear equation?
I talked to Junchao; he suggested that I try SNES/tutorial/ex56. I tried that, but I could not find any speedup using the GPU. I could attach some results of "log_view" later if we would like to see that.
We should note that you will only see speedup in the solver, so that problem has to be pretty large. I believe Mark has good results with it. The assembly is still all on the CPU. I am working on this over break, and hope to have a CEED version of it by the new year.
Are both function and matrix assmelies on CPU? Or just the matrix assembly?
There is no GPU assembly right now.
Matt
OK, I will try to check the solver part
Thanks, again
Fande
Matt
Appreciate any instructions/comments about running a simple PETSc GPU example to get a speedup.
Fande
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
participants (1)
Matthew Knepley
