User manual converted to/for Doxygen
Dear all, I've finally completed my conversion of the user manual to Doxygen. An online copy can be found here: http://krupp.iue.tuwien.ac.at/petsc-doxygen/usermanual.html This completes the raw conversion of the existing documentation to a doxygen-based system. Further polishing is certainly required, but certain parts may not be possible without actually touching the existing sowing-centered code comments in the source tree. The not-so-ideal thing is that the LaTeX manual and the doxygen pages exist in parallel. Converting from either of them to the other is not possible in an automatic way. Thus, I suggest to introduce a unified Markdown-like format, from which we can generate both types of documentation. Some customizations is certainly necessary because of the way the text needs to be written. For example, in a PDF it is natural to write "Further explanation is given in Chapter 42", while in an HTML documentation one ideally provides a link of the type "[More information on Foo]". Similarly, some large code snippets included directly in the PDF manual can be linked easily within an HTML documentation. Best regards, Karli PS: To avoid confusion: PETSc will keep its existing documentation system for a while. We did not yet agree on the/any future of this doxygen-based approach.
participants (1)
Karl Rupp
