Re: [petsc-dev] Regression tests
Slightly off topic - but I have Buildbot set up locally to keep an eye on petsc-dev and various branches of petsc that I care about (if you are curious see http://stereolab.ese.ic.ac.uk:8080/waterfall - knock yourself out with the force build button if you wish) Because this is a bot, 99% of time I only care about "pass", "fail" ($? != 0 is counted as a fail), "warning". For the testharness in our own application code we just parse the output of unit tests for "pass", "fail" and "warning" and list the tests that gave a warning or fail at the end so a developer can take a closer look. I would like to do a similar grepping for PETSc tests. Are the tests messages standardised so I can do this? At first glance I have: "pass" == "run successfully with" "warning" == "Possible problem with" "fail" == "mpiexec not found" or $? != 0 Cheers Gerard
participants (1)
Gerard Gorman
