Re: [petsc-dev] building on Spock
Hey Mark, I believe the problem is in this line: export PE_MPICH_GTL_DIR_amd_gfx908="-L/opt/cray/pe/mpich/8.1.4/gtl/lib" "8.1.4" should be replaced with "default" since I think that version is in flux. On Fri, Aug 13, 2021 at 1:49 PM Mark Adams <[email protected]> wrote:
I was building on Spock a few weeks ago, but am getting these errors now. I have a setup with this environment and get this error.
Any ideas?
Thanks, Mark
module load craype-accel-amd-gfx908 module load rocm module load emacs module load zlib module load autoconf automake libtool
## These must be set before compiling so the executable picks up GTL export PE_MPICH_GTL_DIR_amd_gfx908="-L/opt/cray/pe/mpich/8.1.4/gtl/lib" export PE_MPICH_GTL_LIBS_amd_gfx908="-lmpi_gtl_hsa"
## These must be set before running export MPIR_CVAR_GPU_EAGER_DEVICE_MEM=0 export MPICH_GPU_SUPPORT_ENABLED=1 export MPICH_SMP_SINGLE_COPY_MODE=CMA
participants (1)
Aaron Scheinberg
