array ownership of MatCreateMPIAIJWithSplitArrays and MatCreateSeqAIJWithArrays
23 Jul
23 Jul
'16
2:36 p.m.
I’m interfacing a FEM library with PETSc. They already use Hypre and so they have a valid distributed CSR format (except for the diagonal entry of the diagonal block :-)) For efficiency reasons, I was thinking of using MatCreateMPIAIJWithSplitArrays and MatCreateSeqAIJWithArrays; However, If using these functions as they are now I will need to keep track of the allocated arrays, even with referencing objects, and this could be annoying and cumbersome. A trivial fix would be to add an extra PetscCopyMode parameter to these routines, so that PETSc can take ownership of the arrays. Thoughts? Any objection?
3671
Age (days ago)
3671
Last active (days ago)
0 comments
1 participants
participants (1)
Stefano Zampini
