Re: [petsc-dev] broken options handling with intel 16.0 compilers on mac OS
Well - the petscconf.h is identicall for both builds. So the change in behavior must be due to some internal changes in ifort on Mac [as you say - it works fine on linux] Can you try using the branch 'balay/ftn-command_argument' - and see if that works for you? Satish On Wed, 16 Sep 2015, Blaise A Bourdin wrote:
Hi Satish,
It is at https://filestogeaux.lsu.edu/public/download.php?FILE=bourdin/38806CDddLJ
On Sep 16, 2015, at 10:34 AM, Satish Balay <[email protected]> wrote:
Do you have configure.log fr intel-15 compiler - on the same machine?
It would be good to compare petscconf.h between intel-15 and intel-16.
bourdin@galerkin:petsc-dev (master)$ diff Darwin-intel15.0-g//include/petscconf.h Darwin-intel16.0-g//include/petscconf.h 85c85 < #define PETSC_LIB_DIR "/opt/HPC/petsc-dev/Darwin-intel15.0-g/lib" ---
#define PETSC_LIB_DIR "/opt/HPC/petsc-dev/Darwin-intel16.0-g/lib" 489c489 < #define PETSC_ARCH "Darwin-intel15.0-g"
#define PETSC_ARCH "Darwin-intel16.0-g” Not very exciting!
I am attaching the one for intel16
participants (1)
Satish Balay
