Re: [petsc-dev] tiny issues in test harness
ecc1beb596a8093f7509ca38016ed30c93784193 works for me. Thanks! #2 Yes, using double quotes works, but it took me a while to figure out why the filter didn't work for me with single quotes. Might be worth mentioning that filters with single quotes might not work correctly in dev manual and/or putting guards into parsing/petsc_testrun. Jakub On 9/26/18 11:00 PM, Scott Kruger wrote:
Fix for #1 is merged into next.
See ecc1beb596a8093f7509ca38016ed30c93784193
For #2, I think it'll work if you use double quotes and egrep. If you do this: cd $PETSC_DIR/src/sys/examples/test grep filter *.c
I think you'll see some examples of complicated filters that Barry got working.
Scott
On 8/14/18 4:05 AM, Jakub Kruzik wrote:
Hi all,
I started using test harness in PERMON and find out a couple of issues with it.
1) multiple "args:" keywords in "test:" in "testset:" are ignored except for the last "args:" keyword. See attached MWE and check it with
python2 ${PETSC_DIR}/config/testparse.py -t ex1.c -v 3
2) single quotes can't be used in "filter:" keyword. E.g. filter: grep 'r =' generates
petsc_testrun ... 'grep 'r =''
resulting in filter being "grep r". Might be worth mentioning this in dev manual and/or putting guards into parsing/petsc_testrun.
Best,
Jakub
participants (1)
Jakub Kruzik
