Re: [petsc-dev] Regression in manualpages generation?
On 6 Apr 2021, at 5:03 PM, Satish Balay <[email protected]> wrote:
https://www.mcs.anl.gov/petsc/petsc-current/ is from petsc-3.15.0 - and is normally gets updated with the next patch release - i.e petsc-3.15.1. [ok - I'll update now with current release snapshot]
Ah, of course, I don’t know why I checked there instead of the dev version, my bad. Well, thank you for updating the 3.15.0 pages as well I guess. Thanks, Pierre
Also dev pages should get updated daily [there is a bug here that I should fix]
With the latest snapshots - both the pages appear to list MatGetRow_MPIDense
https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetRow.h... https://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Mat/MatGetRow.html
Satish
On Tue, 6 Apr 2021, Pierre Jolivet wrote:
Thanks for the recent MR. This sadly only partially addresses the issue. https://www.mcs.anl.gov/petsc/petsc-3.14.6/docs/manualpages/Mat/MatGetRow.ht... <https://www.mcs.anl.gov/petsc/petsc-3.14.6/docs/manualpages/Mat/MatGetRow.html> correctly has MatGetRow_MPIDense while https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetRow.h... <https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatGetRow.html> hasn’t.
Thanks, Pierre
On 3 Apr 2021, at 1:24 PM, Patrick Sanan <[email protected]> wrote:
I think this was likely a non-portable regex that was being used to match the function signatures, causing it to miss anything with an internal "s" in the function name. Here's a quick fix for the release branch:
https://gitlab.com/petsc/petsc/-/merge_requests/3813 <https://gitlab.com/petsc/petsc/-/merge_requests/3813>
(This sort of thing will become easier to work with, soon, as we'll have an automated doc build which can be examined for each MR.)
P.S. nice email address!
Am 03.04.2021 um 11:19 schrieb Patrick Sanan <[email protected] <mailto:[email protected]>>:
That isn't expected - thanks for pointing this out! I can reproduce locally so will take a look.
Am 03.04.2021 um 11:10 schrieb Pierre Jolivet <[email protected] <mailto:[email protected]>>:
Hello, https://www.mcs.anl.gov/petsc/petsc-3.14/docs/manualpages/Mat/MatTranspose.h... <https://www.mcs.anl.gov/petsc/petsc-3.14/docs/manualpages/Mat/MatTranspose.html> lists available implementations while https://www.mcs.anl.gov/petsc/petsc-3.15/docs/manualpages/Mat/MatTranspose.h... <https://www.mcs.anl.gov/petsc/petsc-3.15/docs/manualpages/Mat/MatTranspose.html> doesn’t. Is this expected?
Thanks, Pierre
participants (1)
Pierre Jolivet
