I'll test this. I'm impressed by how much code you have removed and I'm happy to put it in petsc-dev, but we're building up a lot of changes to petsc-3.3. Should we call the next patch release 3.3.1 instead of 3.3p? It's a significant enough change that people should be able to test for it with the PETSC_VERSION_ macros. This line can certainly be removed. +#define PETSC_MAX_YAML_LEN 128000 On Fri, Aug 17, 2012 at 1:52 PM, Blaise Bourdin <[email protected]> wrote:
Here is a revised version of my YAML patch that eliminates the limit on the yaml file length. Is there any rational objection to pushing it to petsc-3.3 and petsc-dev?
Blaise
-- Department of Mathematics and Center for Computation & Technology Louisiana State University, Baton Rouge, LA 70803, USA Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
participants (1)
Jed Brown
