BTW, I'm pretty sure that long, long time ago I asked for this, and some of you rejected the idea, but I cannot remember the rationale right now. The current state of PCShell somewhat complicates the access to internal PC stuff (eg. linear operators). On Mon, Sep 22, 2008 at 1:08 PM, Barry Smith <[email protected]> wrote:
On Sep 22, 2008, at 7:59 AM, Dave May wrote:
Why is the first pointer in PCSHELL operations the user context whereas in MATSHELL the first pointer is of type Mat ?? Seems slightly inconsistent.
Good question, these were done at different times and only later did we realize the inconsistency. This is something that should be fixed in petsc-dev.
Barry
I guess the first argument for the PCSHELL should become the pc.
On Mon, Sep 22, 2008 at 8:31 PM, Michel Cancelliere <[email protected]> wrote:
Hello,
I have problems with the implementation of a user-defined pc, basically my program is in a cycle, for with which he is called by matlab each time it seeks to solve a linear system, the problem is that in the first iteration of the for-cycle the preconditioner works very well, then fails to convergence. It may be some parameters that I setting wrong? I'am attaching my program code.
Thank you,
Michel
-- Lisandro Dalc�n --------------- Centro Internacional de M�todos Computacionales en Ingenier�a (CIMEC) Instituto de Desarrollo Tecnol�gico para la Industria Qu�mica (INTEC) Consejo Nacional de Investigaciones Cient�ficas y T�cnicas (CONICET) PTLC - G�emes 3450, (3000) Santa Fe, Argentina Tel/Fax: +54-(0)342-451.1594
participants (1)
Lisandro Dalcin
