Re: [petsc-dev] Error of petsc-3.15 with python-3.10
On Wed, May 12, 2021 at 5:51 AM Antonio T. sagitter < [email protected]> wrote:
Hi all.
I'm sorry if using python-3.10 is not in your plan yet and this mail is inappropriate now.
This is an error from a build of PETSc-3.15 in a Python-3.10.0b1 (on Fedora 35 , GCC-11.1.1):
+ make V=1 MAKE_NP=2 PETSC_DIR=/builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0 PETSC_ARCH=x86_64 all
We need makefile parsing, which is currently in distutils. Casual Googling does not find it in any other packages. Where has Python moved it? I am assuming they have not just dropped it on the floor. Thanks, Matt
/usr/bin/python3 ./config/gmakegen.py --petsc-arch=x86_64
/builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/./config/gmakegen.py:4: DeprecationWarning: The distutils package is deprecated and slated for removal in Python 3.12. Use setuptools or check PEP 632 for potential alternatives
from distutils.sysconfig import parse_makefile
/builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/./config/gmakegen.py:4: DeprecationWarning: The distutils.sysconfig module is deprecated, use sysconfig instead
Traceback (most recent call last):
File "/builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/./config/gmakegen.py", line 345, in <module>
main(petsc_arch=opts.petsc_arch, pkg_dir=opts.pkg_dir, pkg_name=opts.pkg_name, pkg_arch=opts.pkg_arch, pkg_pkgs=opts.pkg_pkgs, output=opts.output, verbose=opts.verbose)
File "/builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/./config/gmakegen.py", line 328, in main
petsc.summary()
File "/builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/./config/gmakegen.py", line 255, in summary
self.mistakes.summary()
File "/builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/./config/gmakegen.py", line 79, in summary
raise RuntimeError('PETSc makefiles contain mistakes or files are missing on filesystem.\n%s\nPossible reasons:\n\t1. Files were deleted locally, try "hg revert filename" or "git checkout filename".\n\t2. Files were deleted from repository, but were not removed from makefile. Send mail to [email protected].\n\t3. Someone forgot to "add" new files to the repository. Send mail to [email protected].' % ('\n'.join(self.mistakes)))
RuntimeError: PETSc makefiles contain mistakes or files are missing on filesystem.
Makefile contains directory not on filesystem: /builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/src/sys: ['\\']
Makefile contains directory not on filesystem: /builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/src/mat/impls/aij/seq: ['\\']
Makefile contains directory not on filesystem: /builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/src/ksp/ksp/impls: ['\\']
Makefile contains directory not on filesystem: /builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/src/ksp/pc/impls: ['ml\\']
Makefile contains directory not on filesystem: /builddir/build/BUILD/petsc-3.15.0/petsc-3.15.0/src/tao/complementarity/impls:
['#', 'isls', 'rscs']
Possible reasons:
gmakefile:67: x86_64/lib/petsc/conf/files: No such file or directory
Can you say me what's cause it? (Same configuration works with Python-3.9)?
Regards. -- --- Antonio Trande Fedora Project mailto: [email protected] GPG key: 0x29FBC85D7A51CC2F GPG key server: https://keys.gnupg.net/
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
participants (1)
Matthew Knepley
