Re: [petsc-dev] where is type(Mat) defined?
On Jul 17, 2012, at 10:51 PM, Barry Smith wrote:
If you are using Fortran modules (and being a FORTRAN lover you are :-). Then you have to rebuild the modules whenever you change these files. Do make cmake after you edit the file
You bet I am... make cmake is what I was missing. Is it possible to apply the attached patch to petsc-3.3 and petsc-dev? It adds the data type, and the fortran binding for MatNullSpaceView. Blaise
Barry
On Jul 17, 2012, at 10:41 PM, Blaise Bourdin wrote:
I am still trying to figure out how to add support for MatNullSpace with fortran data types. As I said in a previous email, adding the statement type MatNullSpace PetscFortranAddr:: v end type MatNullSpace in include/finclude/ftn-custom/petscmatdef.h90
is not enough.
Furthermore, if I remove the corresponding statement type Mat PetscFortranAddr:: v end type Mat for Mat, I can still compile code with a statement like Type(Mat) :: M
It looks like the fortran data type for Mat is defined somewhere else, but I can't figure out where. Can anybody shine some light for me?
Blaise -- Department of Mathematics and Center for Computation & Technology Louisiana State University, Baton Rouge, LA 70803, USA Tel. +1 (225) 578 1612, Fax +1 (225) 578 4276 http://www.math.lsu.edu/~bourdin
participants (1)
Blaise Bourdin
