Summary of attempts to get PETSc to work with mingw32-gfortran and MPI
Brief summary PETSc/mingw32-gfortran/HPCPACK (mpich2) fails because mingw32-gfortran cannot link a simple MPI program. There seem also to be some problems with munging of the paths when using "win32fe cl" for the C/C++ compiler. PETSc/mingw32-gfortran/OpenMPI does not have the above basic link problem, but it fails due to problems with the PETSc build system. When using CL (VS10), there are problems in option translation (path munging). When using mingw32-gcc/++, there seem to be failures with the inclusion of some petsc generated configuration files. Longer report Attempts to get PETSc-MPI-mingw-gfortran to work: HPCPACK (mpich2): Ultimately found a problem with the fortran library: $ cat conftestf.f program main include 'mpif.h' integer ierr call mpi_init(ierr) end $ mingw32-gfortran -o conftestf.o -c conftestf.f -I /winsame/contrib-mingw/microsoft-hpc-mingw/Include xena.cary$ mingw32-gfortran -o conftestf.exe conftestf.o -L/winsame/contrib-mingw/microsoft-hpc-mingw/Lib/i386 -lmsmpifec -lmsmpi Warning: .drectve `/DEFAULTLIB:"uuid.lib" /DEFAULTLIB:"uuid.lib" ' unrecognized /winsame/contrib-mingw/microsoft-hpc-mingw/Lib/i386/msmpifec.lib(obj/i386/mpif.obj):(.text[_mpi_recv_]+0x1f): undefined reference to `_imp__MPI_F_STATUS_IGNORE' ... The missing symbol has a different name in the library, $ link /dump /exports "C:\winsame\contrib-mingw\microsoft-hpc-mingw\Lib\i386\msmpi.lib" | grep F_STATUS_IGNORE _MPI_F_STATUS_IGNORE i.e., no _imp_ starting it. OPENMPI (OpenMPI_v1.5.4-win32 binary package) --with-fc='mingw32-gfortran' CL and OpenMPI: directories get munged, changes name of libgfortran.a --with-cc='win32fe cl' \ --with-cxx='win32fe cl' \ --with-mpi-include=/winsame/contrib-mingw/OpenMPI_v1.5.4-win32/include \ --with-mpi-lib="[/winsame/contrib-mingw/OpenMPI_v1.5.4-win32/lib/libmpi_f77d.lib,/winsame/contrib-mingw/OpenMPI_v1.5.4-win32/lib/libmpi.lib,/winsame/contrib-mingw/OpenMPI_v1.5.4-win32/lib/libopen-pal.lib,/winsame/contrib-mingw/OpenMPI_v1.5.4-win32/lib/libopen-rte.lib]" \ configureDynamicLibraries from PETSc.utilities.sharedLibraries(/winsameLINK : fatal error LNK1104: cannot open file 'libgfortran.lib'^M ret = 512 Pushing language C Popping language C in /winsame/builds-mingw/facetsall-mingw/petsc-3.1-p8/par/bin/win32fe/win32fe cl -o conftest.exe -MT -wd4996 -O2 -g conftest.o -lgfortran -L/winsame/builds-mingw/facetsall-mingw/petsc-3.1-p8/par/c:/mingw/lib/gcc/mingw32/4.6.1 -L/winsame/builds-mingw/facetsall-mingw/petsc-3.1-p8/par/c:/mingw/lib/gcc -L/winsame/builds-mingw/facetsall-mingw/petsc-3.1-p8/par/c:/mingw/mingw32/lib -L/winsame/builds-mingw/facetsall-mingw/petsc-3.1-p8/par/c:/mingw/lib -L/mingw/lib -lgfortran -lmingw32 -lgcc_s -lmoldname -lmingwex -lmsvcrt -lquadmath -lm -ladvapi32 -lshell32 -luser32 Source: #include "confdefs.h" #include "conffix.h" int main() { ; return 0; } Popping language C compilers: Cannot compile/link C with /winsame/builds-mingw/facetsall-mingw/petsc-3.1-p8/par/bin/win32fe/win32fe cl. libgfortran.lib does not exist, but libgfortran.a does. mingw32-gcc and OpenMPI: --with-cc='mingw32-gcc' \ --with-cxx='mingw32-g++' \ Directories not munged, but there is something wrong, it seems, with the includes of PETSc's build system. sh: mingw32-g++ -c -o conftest.o -Wall -Wwrite-strings -Wno-strict-aliasing -O -I/winsame/contrib-mingw/OpenMPI_v1.5.4-win32/include conftest.cc Executing: mingw32-g++ -c -o conftest.o -Wall -Wwrite-strings -Wno-strict-aliasing -O -I/winsame/contrib-mingw/OpenMPI_v1.5.4-win32/include conftest.cc sh: Possible ERROR while running compiler: ret = 256 error message = {In file included from conftest.cc:3:0:^M /winsame/contrib-mingw/OpenMPI_v1.5.4-win32/include/mpi.h:1082:25: error: expected ')' before 'comm'^M /winsame/contrib-mingw/OpenMPI_v1.5.4-win32/include/mpi.h:1096:25: error: expected unqualified-id before 'int'^M /winsame/contrib-mingw/OpenMPI_v1.5.4-win32/include/mpi.h:1096:25: error: expected ')' before 'int'^M } Source: #include "confdefs.h" #include "conffix.h" #include <mpi.h> int main() { ; return 0; } Line 1082 is OMPI_DECLSPEC MPI_Fint MPI_Comm_c2f(MPI_Comm comm); Line 1096 is OMPI_DECLSPEC MPI_Comm MPI_Comm_f2c(MPI_Fint comm); I can compile the above source without the extra conf includes: $ cat conftestc.c #include <mpi.h> int main() { ; return 0; } $ mingw32-g++.exe -c -o conftestc.o -O -I/winsame/contrib-mingw/OpenMPI_v1.5.4-win32/include conftestc.c $ BTW, Link with mingw32-g++ fails: $ mingw32-g++ -o conftestc.exe conftestc.o -L/winsame/contrib-mingw/OpenMPI_v1.5.4-win32/lib -llibmpi_cxx -llibmpi -llibopen-pal -llibopen-rte conftestc.o:conftestc.c:(.text$_ZN3MPI2Op4InitEPFvPKvPviRKNS_8DatatypeEEb[MPI::Op::Init(void (*)(void const*, void*, int, MPI::Datatype const&), bool)]+0x1b): undefined reference to `ompi_mpi_cxx_op_intercept' conftestc.o:conftestc.c:(.text$_ZNK3MPI9Intracomm11Create_cartEiPKiPKbb[MPI::Intracomm::Create_cart(int, int const*, bool const*, bool) const]+0x81): undefined reference to `MPI::Comm::Comm()' ...
participants (1)
John R. Cary
