ref: https://lists.mcs.anl.gov/pipermail/petsc-dev/2016-April/019014.html I've deleted all deveopment branches that are already merged into maint (v3.8) from https://bitbucket.org/petsc/petsc However if you wish to remove these branches from your clone - it has to be done manually (in each clone). To get this list of branches to delete - you can do: git branch --merged v3.8 |egrep -v " (maint|master|next)" > branches_to_delete After *verifying* the list is correct - and ok to delete - they can be deleted with: git branch -d `cat branches_to_delete` And to sync the [deleted] remove branch list info - you can do: git fetch -p For more housekeeping - look at the remaining local and remote branches and figure-out what to do. [perhaps some of them are intermediate branches during rebase - or abandoned features that should be deleted]. For my branches - I would do: git branch git branch -r |grep balay Satish ---------------- reference for self: $ git branch -r --merged v3.8 |egrep -v origin/\(maint\|master\|next\) |sed -e s%origin/%:% > remote_branches_to_delete $ git push -u origin `cat remote_branches_to_delete` To bitbucket.org:petsc/petsc.git - [deleted] Fande-Kong/feature_snes_has_dm - [deleted] Fande-Kong/gasm_check_setsubdomains - [deleted] Fande_Kong/PetscOptionsGetUnusedOptions - [deleted] balay/add-blas-dep-to-fftw/maint - [deleted] balay/add-cxx-f-math-z-libs-deps - [deleted] balay/add-fstack-protector - [deleted] balay/add-ftn-PetscDataTypeGetSize - [deleted] balay/add-matlab-test - [deleted] balay/add-mvapich-version-check - [deleted] balay/add-petsc4py-python - [deleted] balay/add-prefix-test - [deleted] balay/bugfix-klu-64bitindices/maint - [deleted] balay/check-dep-download - [deleted] balay/clang-Wcomma - [deleted] balay/disable-msmpi-mpiio - [deleted] balay/disable-ssh-hwloc-bydefault - [deleted] balay/disable-visibility-for-static-build - [deleted] balay/enable-download-zlib-static - [deleted] balay/fix-MatGetRowIJ_SeqAIJ_Inode - [deleted] balay/fix-PetscInt-scanf/maint - [deleted] balay/fix-c89-func-test/maint - [deleted] balay/fix-checkMKL - [deleted] balay/fix-clang-va_start-warning - [deleted] balay/fix-configure-lm-Ofast - [deleted] balay/fix-ctable-hash - [deleted] balay/fix-eigen-prefix - [deleted] balay/fix-format-security/maint - [deleted] balay/fix-isgnu-for-ccache - [deleted] balay/fix-matlab-test - [deleted] balay/fix-ml-suitesparse-single - [deleted] balay/fix-mpi-ver-test/maint - [deleted] balay/fix-mumps-intel17-openmpi/maint - [deleted] balay/fix-pic-check-ubuntu1610/maint - [deleted] balay/fix-quad-complex-from-cxx - [deleted] balay/fix-redundant-decls-warnings-master - [deleted] balay/fix-scalapack-pic/maint - [deleted] balay/fix-superlu-nof - [deleted] balay/fix-win32fe-tmp-obj-usage - [deleted] balay/fix-with-cuda - [deleted] balay/fix-xcode8-warning/maint - [deleted] balay/gfortran-4.4-fixes - [deleted] balay/hdf5-switch-zlib-to-odep - [deleted] balay/improve-git-externalpackage-co-error- message - [deleted] balay/mkl-use-detected-mathlib/maint - [deleted] balay/move_mpiinc_to_cudac_flags/maint - [deleted] balay/mpiuni-namespace-fc - [deleted] balay/osx-mkl/maint - [deleted] balay/print-mpi.h-info/maint - [deleted] balay/ptscotch-build-esmumps/maint - [deleted] balay/split-mpiuni-f-def - [deleted] balay/switch-pflotran-to-git-mirror - [deleted] balay/sync-64bit-mpitype - [deleted] balay/test - [deleted] balay/test-with-mpich-errorcheck - [deleted] balay/testharness-wPETSC_DIR - [deleted] balay/to-maint-fix-cpardiso-mkl-detection - [deleted] balay/update-MUMPS_5.0.2 - [deleted] balay/update-PETSC_ARCH-errorcheck/maint - [deleted] balay/update-cmake-elemental-v0.87-squashed - [deleted] balay/update-hdf5-netcdf-squashed - [deleted] balay/update-hypre-v2.11.1/maint - [deleted] balay/update-ml-v6.2-p4/maint - [deleted] balay/update-mpich-3.3a2-squashed - [deleted] balay/update-mumps-5.1.1 - [deleted] balay/update-pastix-5.2.3/maint - [deleted] balay/update-pgi-test/maint - [deleted] balay/update-ptscotch-6.0.4/maint - [deleted] balay/update-sowing-1.1.25-p1 - [deleted] balay/update-sowing-enum - [deleted] balay/update-strumpack-1.0.4 - [deleted] balay/update-xsdk-oct-2016 - [deleted] balay/update_superlu_and_dist/maint - [deleted] balay/use-PetscInt64 - [deleted] balay/vs6-warning-fixes - [deleted] balay/win-icl - [deleted] balay/win32-dll - [deleted] balay/with-fortran-bindings - [deleted] barry-update-hypre-2.12.0 - [deleted] barry/Sander/fix-pcreset-fieldsplit - [deleted] barry/add-MatSeqSBAIJGetArray - [deleted] barry/add-bcgsl-test - [deleted] barry/add-dmda-rotate-boundary-conditions- example - [deleted] barry/add-download-serial-mumps - [deleted] barry/add-errorcheck-pcfieldsplitgetsubksp - [deleted] barry/add-fortran-interfaces - [deleted] barry/add-fortran-tsadaptsettype - [deleted] barry/add-ghost-neumann - [deleted] barry/add-intro-help - [deleted] barry/add-isload-binary - [deleted] barry/add-matfdcoloring-ghosted-example - [deleted] barry/add-matgetrow-interface - [deleted] barry/add-matshell-matgetdiagonalblock- fortran - [deleted] barry/add-missing-apis/maint - [deleted] barry/add-missing-fixreturnchar/maint - [deleted] barry/add-missing-test-case/maint - [deleted] barry/add-openblas-download - [deleted] barry/add-parms-test - [deleted] barry/add-petsc-stdout-fortran - [deleted] barry/add-real-object-support-petscbinaryio - [deleted] barry/add-snes-divtol - [deleted] barry/add-snes-dmda-periodic - [deleted] barry/add-trilinos-support-without-download - [deleted] barry/add-tsadapt-default/maint - [deleted] barry/add-yaml-options-test - [deleted] barry/allow-changing-normtype-pcside- afterset - [deleted] barry/allow-multiple-downloaddirnames - [deleted] barry/cleanup-external-mat-solver-packages - [deleted] barry/consistent-formating-ascii-solver- viewers - [deleted] barry/convert-clique-to-elemental - [deleted] barry/custom-vecscatter-view-fortran - [deleted] barry/do-not-test-random-mpicc-with-mpi-dir - [deleted] barry/docs-petscversion - [deleted] barry/error-matload-if-dense-format/maint - [deleted] barry/errorcheck-fortran- petscobjectviewfromoptions - [deleted] barry/extend-pcmg-galerkin - [deleted] barry/f2clibs-may-need-lquadmath - [deleted] barry/feature-aij-subtypes - [deleted] barry/feature-check-mpi-library-runtime - [deleted] barry/feature-fortran-petscerror - [deleted] barry/feature-matdenseplacearray - [deleted] barry/feature- matfdcoloringgetperturbedcolumns-f90 - [deleted] barry/feature-petscgetversionnumber - [deleted] barry/feature-simple-spectral - [deleted] barry/feature-snes-force-iteration - [deleted] barry/feature-ts-monitor-solution - [deleted] barry/fix-chaco-from-trilinos - [deleted] barry/fix-compilerflags-for-packages - [deleted] barry/fix-const-matdiagonalscale - [deleted] barry/fix-dead-variables - [deleted] barry/fix-dmcreatematrix-dmda - [deleted] barry/fix-dmdacreate - [deleted] barry/fix-dmshellsetglobalvector - [deleted] barry/fix-duplicate-help - [deleted] barry/fix-dynamic_library_preload - [deleted] barry/fix-fortran-imaginary-part - [deleted] barry/fix-fortran-interfaces-matsetvalues - [deleted] barry/fix-huge-flaw-in-ts - [deleted] barry/fix-ignore-returns - [deleted] barry/fix-kspnormsupporttablereset - [deleted] barry/fix-kspnormtypes - [deleted] barry/fix-log_view - [deleted] barry/fix-matmffd-type-fortran/maint - [deleted] barry/fix-matmpixxxsetpreallocation- reentrant - [deleted] barry/fix-matreuse - [deleted] barry/fix-multiple-identical-monitors/maint - [deleted] barry/fix-nonnorm-convergencetest - [deleted] barry/fix-osx-static-libraries - [deleted] barry/fix-package-precision-dependency - [deleted] barry/fix-pcmgsetcyclesonlevel - [deleted] barry/fix- petscobjectcopyfortranfunctionpointers - [deleted] barry/fix-petscobjectsetoptionsprefix/maint - [deleted] barry/fix-seterrq - [deleted] barry/fix-snes-qn-powell/maint - [deleted] barry/fix-some-clang-warnings - [deleted] barry/fix-source-clang - [deleted] barry/fix-successful-numerical- factorization-after-failure/maint - [deleted] barry/fix-successful-numerical- factorization-after-failure/master - [deleted] barry/fix-testex182/maint - [deleted] barry/fix-tfs - [deleted] barry/fix-tscomputerhsjacobianconstant/maint - [deleted] barry/fix-umfpack-empty-matrix - [deleted] barry/fix-use-objectid-not-object-for- comparison-in-ts - [deleted] barry/fix-vecaypx-petschecksametypeandcomm - [deleted] barry/fix-xml-logging - [deleted] barry/fix/even-huger-flaw-in-ts - [deleted] barry/forbid-spaces-in-petscdir-prefix - [deleted] barry/fortran-update - [deleted] barry/get-factor-failure-information-from- mat - [deleted] barry/half-precision - [deleted] barry/housekeeping-1 - [deleted] barry/housekeeping-2 - [deleted] barry/improve-fortran-callback-error- checking - [deleted] barry/improve-gcov - [deleted] barry/improve-mathasoperation - [deleted] barry/improve-matnullspace-usage - [deleted] barry/improve-pcasm-islocal - [deleted] barry/improve-tao-test-gradient - [deleted] barry/improve-ts-trajectory-viz - [deleted] barry/install-examples - [deleted] barry/make-functions-static - [deleted] barry/make-test-checks-external-packages - [deleted] barry/metis-gkrand - [deleted] barry/minor-cleanup - [deleted] barry/more-fortran-updates - [deleted] barry/namespace-events - [deleted] barry/pcmgsetsmoothupdown-if-no-change - [deleted] barry/remove-funct - [deleted] barry/remove-papi - [deleted] barry/secant-update-infinity - [deleted] barry/tellmycell - [deleted] barry/tests-ksps - [deleted] barry/ts-error-explicit-method-ifunction - [deleted] barry/ts-view-tolerances - [deleted] barry/tsadapt-one-line-monitor - [deleted] barry/update-blaslapack-support-download- batch - [deleted] barry/update-petscfileretrieve - [deleted] barry/update-ssl-to-1-1 - [deleted] barry/update-trilinos-build - [deleted] barry/use-fortran-kind-consistently - [deleted] barry/vecscattercreatetozero-fortran-null - [deleted] blaise/exodus-update-git - [deleted] dalcinl/ts-monitor-lg-timestep-log - [deleted] damalbel/dmnetwork_dist - [deleted] damalbel/dmnetwork_nest_indexing - [deleted] damalbel/dmnetworkex1 - [deleted] damalbel/dmnetworkex1_local - [deleted] deleeke/feature-configure-googletest - [deleted] dmaldona/dmnetwork_ex2 - [deleted] dmay/developerlistupdate - [deleted] dmay/dmswarm-fixes - [deleted] dmay/dmswarm-remove-binary-readwrite - [deleted] dmay/swarm-pic-tools - [deleted] dmay/swarm-pic-tools-v3.8 - [deleted] dmay/telescope-nullspace-fix - [deleted] dmay/test_matzerorows - [deleted] elbueler/snesvi-ex9-simplification - [deleted] emil/fix-glee-man-pages - [deleted] emil/fix-ts-ex12 - [deleted] emil/rename-gl-to-glle - [deleted] emil/ts-glee - [deleted] hongzh/adjoint-parallel - [deleted] hongzh/fix-tao-draw-monitor - [deleted] hongzh/fix-tstraj - [deleted] hongzh/ts-direct-sa - [deleted] hzhang/DMNetworkAddComp - [deleted] hzhang/ElementalHerk - [deleted] hzhang/advection-example - [deleted] hzhang/bugfix-RedundantMat/master - [deleted] hzhang/bugfix-matdestroysubmats - [deleted] hzhang/deprecate-getsubmat - [deleted] hzhang/dmnetwork-rename - [deleted] hzhang/dmnetwork-spJacobian3 - [deleted] hzhang/dmnetwork-vecview - [deleted] hzhang/dmnetwork-vecview-nonascii - [deleted] hzhang/fix-Matredundant-BAIJ - [deleted] hzhang/fix-blockedIS-submat - [deleted] hzhang/fix-dmi-blocksize - [deleted] hzhang/fix-elementalSetOption - [deleted] hzhang/fix-getsubmats-reuse - [deleted] hzhang/fix-ilu0-baij - [deleted] hzhang/fix-mat-ex72 - [deleted] hzhang/fix-matcreate-null-a - [deleted] hzhang/fix-matduplicate_mpiaij_xxx - [deleted] hzhang/fix-matgetfactor-err - [deleted] hzhang/fix-matgetsubmat_sbaij - [deleted] hzhang/fix-matgetsubmatrices-mpiaij - [deleted] hzhang/fix-matmatmatmult - [deleted] hzhang/fix-nonscalable-ctable-use - [deleted] hzhang/fix-pc-PBJacobi-flops - [deleted] hzhang/fix-pcfailedreason - [deleted] hzhang/fix-ptap-seqaij - [deleted] hzhang/fix-superlu_dist-reuse-factornumeric - [deleted] hzhang/fix-superlu_dist-reuse-factornumeric1 - [deleted] hzhang/fix_matview_mpisbaij - [deleted] hzhang/mat-help/master - [deleted] hzhang/mat-structureonly - [deleted] hzhang/matmatops_mpiaij4np1 - [deleted] hzhang/matptap-info - [deleted] hzhang/matptap-scalable - [deleted] hzhang/matseqbaij_bs11 - [deleted] hzhang/mkl_pardiso_matgetinertia - [deleted] hzhang/mpirart - [deleted] hzhang/opt-choleskyfactornumeric - [deleted] hzhang/opt-dmnetwork - [deleted] hzhang/opt-dmnetwork-ex1 - [deleted] hzhang/opt-matfdcoloringsetup - [deleted] hzhang/opt-matgetsubmatrices-mpiaij - [deleted] hzhang/opt-matgetsubmatrices-mpibaij - [deleted] hzhang/opt-matgetsubmatrices-rebased-v2 - [deleted] hzhang/opt-matmatmult-nonscalable - [deleted] hzhang/opt_scalable_MatCreateSubMatrix - [deleted] hzhang/rename_matgetsubmats - [deleted] hzhang/reorg-matdestroysubmats - [deleted] hzhang/scalable_MatCreateSubMatrix - [deleted] hzhang/superlu_dist-getdiaU - [deleted] hzhang/ts-ex9busdmnetwork - [deleted] hzhang/vec-ex28fix - [deleted] jed/Wint-in-bool-context - [deleted] jed/cleanup - [deleted] jed/cleanup-report-tests - [deleted] jed/config-mpi-hashline - [deleted] jed/dmda-mat-setfromoptions - [deleted] jed/fix-dm-dt-test-output-zero - [deleted] jed/fix-dmda-ex51 - [deleted] jed/fix-dmdagetcellpoint-bounds-check - [deleted] jed/fix-fpic-shared-clang - [deleted] jed/fix-matcomposite-ftn-auto - [deleted] jed/matgetrowsum-ones - [deleted] jed/matisrestorelocalmat - [deleted] jed/mpi-semver - [deleted] jed/pkgconfig - [deleted] jed/portable-restrict - [deleted] jed/sf-shared-uni - [deleted] jed/snes-ex5-mms-dedup - [deleted] jose/aijcusparse-fix - [deleted] jose/check-typename - [deleted] jose/cusparse-sethandle - [deleted] jose/fcallback - [deleted] jose/fix-compile-cxx-cuda - [deleted] jose/fix-cusparse-flag - [deleted] jose/maint/tabs-print-class - [deleted] jose/matlrc - [deleted] jose/memory-leak-c89 - [deleted] jose/test-makefile - [deleted] jose/veccuda-tests - [deleted] jose/veccuda-witharray - [deleted] jose/vecplacearray-gpu - [deleted] jose/warning-plexcreate - [deleted] karlrupp/doc-performance-chapter - [deleted] karlrupp/feature-branches-summary - [deleted] karlrupp/feature-viennacl-hybrid - [deleted] karlrupp/feature-viennacl- preconditioners/master - [deleted] karlrupp/fix-MatDuplicate-GPU - [deleted] karlrupp/update-elemental - [deleted] knepley/feature-adapt-interface - [deleted] knepley/feature-bc-values-general - [deleted] knepley/feature-boost-headers-only - [deleted] knepley/feature-configure-eigen-pragmatic - [deleted] knepley/feature-configure-ios-android - [deleted] knepley/feature-convergence-estimator - [deleted] knepley/feature-dm-bc-components - [deleted] knepley/feature-dm-point-location-failure - [deleted] knepley/feature-ex11-simplex - [deleted] knepley/feature-fe-dual-apply - [deleted] knepley/feature-fe-kernel-scalars - [deleted] knepley/feature-fortran-compose - [deleted] knepley/feature-mantle-example - [deleted] knepley/feature-matis-example - [deleted] knepley/feature-parallel-mesh-load - [deleted] knepley/feature-partition-random - [deleted] knepley/feature-plex-3d-sem-order - [deleted] knepley/feature-plex-bdfunc - [deleted] knepley/feature-plex-boundary-values - [deleted] knepley/feature-plex-closure-reorder - [deleted] knepley/feature-plex-ex-advection - [deleted] knepley/feature-plex-gmsh-nodes - [deleted] knepley/feature-plex-interpolation-perf - [deleted] knepley/feature-plex-interpolation-test - [deleted] knepley/feature-plex-particle-example - [deleted] knepley/feature-plex-ply - [deleted] knepley/feature-plex-pragmatic-parallel - [deleted] knepley/feature-plex-project-submesh - [deleted] knepley/feature-plex-projections - [deleted] knepley/feature-plex-replicate - [deleted] knepley/feature-plex-sphere-mesh - [deleted] knepley/feature-plex-tests-new - [deleted] knepley/feature-plex-torus - [deleted] knepley/feature-plex-ts-examples - [deleted] knepley/feature-plex-wedge - [deleted] knepley/feature-realloc - [deleted] knepley/feature-snes-stokes-test - [deleted] knepley/feature-ts-mass-matrix - [deleted] knepley/feature-xdmf-particles - [deleted] knepley/fix-configure-blas-missing - [deleted] knepley/fix-configure-dep-petsc - [deleted] knepley/fix-configure-error-logging - [deleted] knepley/fix-configure-petsc-dep - [deleted] knepley/fix-configure-pragmatic - [deleted] knepley/fix-dm-blocksize - [deleted] knepley/fix-dm-embed-dim - [deleted] knepley/fix-dm-interpolation-parallel - [deleted] knepley/fix-dm-l2g - [deleted] knepley/fix-dm-label-name-fortran - [deleted] knepley/fix-dm-ltog-bs - [deleted] knepley/fix-dm-outputdm - [deleted] knepley/fix-dmlabel-fortran - [deleted] knepley/fix-docs-headers - [deleted] knepley/fix-ex-types - [deleted] knepley/fix-ex18-types - [deleted] knepley/fix-fe-default - [deleted] knepley/fix-fe-fortran - [deleted] knepley/fix-logging-reductions - [deleted] knepley/fix-petscdir-check - [deleted] knepley/fix-petscfe-kernels-ts - [deleted] knepley/fix-plex-bs - [deleted] knepley/fix-plex-cgns - [deleted] knepley/fix-plex-coord-dim - [deleted] knepley/fix-plex-docs - [deleted] knepley/fix-plex-example-logging - [deleted] knepley/fix-plex-examples-cleanup - [deleted] knepley/fix-plex-gmsh-parse - [deleted] knepley/fix-plex-interp-parallel - [deleted] knepley/fix-plex-interp-quad - [deleted] knepley/fix-plex-l2g - [deleted] knepley/fix-plex-link - [deleted] knepley/fix-plex-mat-bs - [deleted] knepley/fix-plex-mat-dm - [deleted] knepley/fix-plex-mf-prec - [deleted] knepley/fix-plex-namespace - [deleted] knepley/fix-plex-order - [deleted] knepley/fix-plex-output - [deleted] knepley/fix-plex-parallel-load - [deleted] knepley/fix-plex-pmat - [deleted] knepley/fix-plex-regression - [deleted] knepley/fix-plex-spectral-order - [deleted] knepley/fix-plex-static - [deleted] knepley/fix-section-fortran-null - [deleted] knepley/fix-snes-ex69-prec - [deleted] knepley/fix-submesh-orientation - [deleted] knepley/fix-tao-ex1 - [deleted] knepley/fix-test-requirements - [deleted] knepley/fix-vec-visibility - [deleted] knepley/test-process-arg - [deleted] mark/gamg-aijtest - [deleted] mark/gamg-doc - [deleted] mark/gamg-fix - [deleted] mark/gamg-snesex56 - [deleted] mark/mat-fix-scaleable - [deleted] mark/snes-ex56 - [deleted] mark/snes-ex56-b - [deleted] mark/snes-ex56-c - [deleted] mlange/feature-plex-med - [deleted] pefarrell/dmshell-asm-clean - [deleted] pefarrell/fas-use-dm-create-restriction - [deleted] pefarrell/mat-galerkin - [deleted] pefarrell/nasm-fixes-clean - [deleted] pr464/pieter_ghysels/pghysels/strumpack- interface-rebased/master - [deleted] pr473/alexfikl/alexfikl/fortran- visibility/maint - [deleted] pr476/psanan/psanan/pc-telescope-subcomm- type/master - [deleted] pr478/knepley/feature-dmplex-adapt/master - [deleted] pr480/alexfikl/alexfikl/fortran- viewer/master - [deleted] pr495/mapdes/snes-compute-final-residual- flag/master - [deleted] pr500/knepley/fix-plex-gmsh/master - [deleted] pr508/psanan/psanan/pc-telescope- nearnullspace/master - [deleted] pr511/vlc1/fix-fortran-dmda-optional- argument/master - [deleted] pr518/kooky089/jacht/PetscInitializeNoArguments -fortran/master - [deleted] pr520/psanan/psanan/vtk-viewer-leak- fix/master - [deleted] pr521/vlc1/fortran- MatNullSpaceGetVecs/master - [deleted] pr523/alexfikl/alexfikl/dmcomposite-local- vectors/master - [deleted] pr527/alexfikl/alexfikl/matshell-fortran- operations/master - [deleted] pr529/sanderarens/plex_gmsh_vertex_sets/master - [deleted] pr530/psanan/mat-viennacl-conversions/master - [deleted] pr540/dmeiser/analyze-examples/master - [deleted] pr543/alexfikl/alexfikl/matnest- transpose/master - [deleted] pr552/vlc1/vlc1/dmcomposite/master - [deleted] pr555/alexfikl/alexfikl/matshell-copy/master - [deleted] pr566/knepley/plex_bd_aux_field/master - [deleted] pr575/knepley/fix-labels-coordinatedm/master - [deleted] pr605/mapdes/runtime- noviewfromoptions/master - [deleted] pr614/sanderarens/fix-plex-hdf5/master - [deleted] pr628/mapdes/scalable-isgtol/master - [deleted] pr630/alexfikl/alexfikl/fortran- missing/master - [deleted] pr643/sanderarens/fix- dmplexlabelcomplete/master - [deleted] pr644/vijaysm/update-dmmoab-5/master - [deleted] pr646/scools/scools/pipebcgs/master - [deleted] pr647/adam_qc/high-order-ams-ads/master - [deleted] pr659/knepley/dmshell-asm-clean/master - [deleted] pr687/Joel-Venzke/fix-hdf5-chunck- size/master - [deleted] pr690/mapdes/feature-plex-user- adjacency/master - [deleted] pr698/scools/scools/pipecgrr-v2/master - [deleted] pr718/hy144328/fix-mumps- configuration/master - [deleted] pr741/psanan/psanan/quad-binary-fixes/maint - [deleted] pr742/francesco_ballarin/mat-missing- diagonal-elemental/master - [deleted] psanan/dm-ex7-fix - [deleted] psanan/fix-KSPPIPEFGMRES-warning/maint - [deleted] psanan/manual-fix - [deleted] psanan/typo-matfindzerodiagonals-man-page - [deleted] psanan/typo-parallelism-2017-01 - [deleted] psanan/typo-publications-2016-11 - [deleted] psanan/usingfortran-typo-fixes - [deleted] rmills/add-aijmkl - [deleted] scott/feature-gmakefile-help - [deleted] scott/test-datafiles-fix - [deleted] scott/test-harness-altfiles - [deleted] scott/test-harness-comments - [deleted] scott/test-harness-f90freeform - [deleted] scott/test-harness-forloopfix - [deleted] scott/test-harness-options - [deleted] scott/test-harness-search2 - [deleted] scott/test-harness-skipdiff - [deleted] scott/test-harness-valgrind-v2 - [deleted] scott/testharness-update1 - [deleted] shri/dmnetwork-add-vertexweights-partition - [deleted] shri/fixes-for-step-restart - [deleted] shri/ts-post-evaluate - [deleted] stefano_zampini/allow-late-matsetblocksizes - [deleted] stefano_zampini/allow-unassembled- computeijacobian - [deleted] stefano_zampini/dmplex-matis-support-2 - [deleted] stefano_zampini/enhancements-fetidp- saddlepoint - [deleted] stefano_zampini/feature-allow-bddc- monolithic - [deleted] stefano_zampini/feature-allow-bddc- monolithic-2 - [deleted] stefano_zampini/feature-allow-dg-dolfin - [deleted] stefano_zampini/feature-allow- mumpsparallelschur - [deleted] stefano_zampini/feature-convert-matnest- matis - [deleted] stefano_zampini/feature-convert-nest-aij- fast - [deleted] stefano_zampini/feature-fetidp-class - [deleted] stefano_zampini/feature-fetidp-ex69 - [deleted] stefano_zampini/feature-getmat-mattranspose - [deleted] stefano_zampini/feature-glvis-viewer - [deleted] stefano_zampini/feature-glvis-viewer- fixdmdependency2 - [deleted] stefano_zampini/feature-gmsh-periodic - [deleted] stefano_zampini/feature-hypre-block-interp - [deleted] stefano_zampini/feature- improvematfactorschur - [deleted] stefano_zampini/feature-kspguess-class - [deleted] stefano_zampini/feature-mathypre - [deleted] stefano_zampini/feature-matis-missingops - [deleted] stefano_zampini/feature-pcbddc-saddlepoint - [deleted] stefano_zampini/feature-plex-simplex-to- tensor - [deleted] stefano_zampini/feature-sparserhs - [deleted] stefano_zampini/feature-usehyprematmatops - [deleted] stefano_zampini/fix-analyzer - [deleted] stefano_zampini/fix-bddcnullspace - [deleted] stefano_zampini/fix-bddcschurs - [deleted] stefano_zampini/fix-bddcschurs- wrongreusematrix - [deleted] stefano_zampini/fix-chebyshev-rhslocked - [deleted] stefano_zampini/fix-dmwswarm-includes- andothers - [deleted] stefano_zampini/fix-ex59-output - [deleted] stefano_zampini/fix-getri-error-mkl - [deleted] stefano_zampini/fix-glvis-staticanalysis - [deleted] stefano_zampini/fix-gmsh-inverted-triangles - [deleted] stefano_zampini/fix-gmsh-noinvtri - [deleted] stefano_zampini/fix-improper-use-of-diag - [deleted] stefano_zampini/fix-matcreatefromparcsr- emptyrowscols - [deleted] stefano_zampini/fix-matgetrowij - [deleted] stefano_zampini/fix-mathypre-example - [deleted] stefano_zampini/fix-mathypre-notpreallocated - [deleted] stefano_zampini/fix-matis - [deleted] stefano_zampini/fix-matis-addlocalprealloc - [deleted] stefano_zampini/fix-matis-missing- setuplayout - [deleted] stefano_zampini/fix-matshift - [deleted] stefano_zampini/fix-mattranspose-is - [deleted] stefano_zampini/fix-matzerorowsaij-bug - [deleted] stefano_zampini/fix-missing-chkerrv-symbol - [deleted] stefano_zampini/fix-p4estview-glvis - [deleted] stefano_zampini/fix-periodic-glvis - [deleted] stefano_zampini/fix-pod-zeroenergy - [deleted] stefano_zampini/fix-rectangular-dense- matisgetmpixaij - [deleted] stefano_zampini/fix-set-but-not-used - [deleted] stefano_zampini/fix-zerosize- matcreateseqaijwitharrays - [deleted] stefano_zampini/hypre-ams-zerointerior- feature - [deleted] stefano_zampini/matis-getinfo - [deleted] stefano_zampini/smallfix-glvis - [deleted] stefano_zampini/smallfix-scaling - [deleted] stefano_zampini/smallfixes-matis - [deleted] test-harness-replacefix - [deleted] tisaac/builder-fix-empty-targets - [deleted] tisaac/dm-boundary-in-ds - [deleted] tisaac/dm-feature-adapt-label - [deleted] tisaac/dm-label-use-is - [deleted] tisaac/dmforest-uncrustify - [deleted] tisaac/dmlabel-fix-clear-bt - [deleted] tisaac/dmlabel-fix-get-stratum-bounds - [deleted] tisaac/dmp4est-feature-mapped-coordinates - [deleted] tisaac/dmp4est-fix-overlap - [deleted] tisaac/dmp4est-fix-set-point-sf - [deleted] tisaac/dmp4est-fix-transfer-point - [deleted] tisaac/dmp4est-set-periodic-domain - [deleted] tisaac/dmp4est-silence-unused - [deleted] tisaac/dmplex-feature-quadrature-in-geom - [deleted] tisaac/dmplex-feature-real-to-ref - [deleted] tisaac/dmplex-fix-hex-box-periodicity - [deleted] tisaac/dmplex-fix-nonaffine-geom - [deleted] tisaac/dmplex-localize-targeted - [deleted] tisaac/dmplex-tree-constraints-aggregate - [deleted] tisaac/dt-feature-avoid-tgamma - [deleted] tisaac/dualspace-feature-symmetry - [deleted] tisaac/dualspace-lagrange-feature- lexicographic - [deleted] tisaac/feature-ex11-conservative-example - [deleted] tisaac/feature-fe-dual-apply - [deleted] tisaac/feature-fortran-compose - [deleted] tisaac/feature-gentest-varsubst - [deleted] tisaac/feature-mantle-example - [deleted] tisaac/feature-plex-deterministic-viewing - [deleted] tisaac/feature-plex-tests-new - [deleted] tisaac/feature-test-force - [deleted] tisaac/feature-vec-tagger - [deleted] tisaac/fix-cmplx - [deleted] tisaac/fix-complex-tagger - [deleted] tisaac/fix-cxx-rules - [deleted] tisaac/fix-dm-tests - [deleted] tisaac/fix-ex3-coords - [deleted] tisaac/fix-hdf5-complex - [deleted] tisaac/fix-ksp-cheby-supported-norm - [deleted] tisaac/fix-med-hdf5 - [deleted] tisaac/fix-petsccmplx - [deleted] tisaac/fix-pipeline-tests - [deleted] tisaac/fix-plex-tree-transfer-inject - [deleted] tisaac/fix-snes-tests-ex2_8 - [deleted] tisaac/is-fix-min-max - [deleted] tisaac/partition-fix-doc - [deleted] tisaac/petscfe-fix-default-quadrature - [deleted] tisaac/petscfe-matching-quadrature-order - [deleted] tisaac/plex-fix-copy-coordinates - [deleted] tisaac/plex-fix-ex6-printf - [deleted] tisaac/plex-fix-partition-overlap - [deleted] tisaac/plex-tree-cleanup-anchor-matrix - [deleted] tisaac/plex-tree-transfer-vec-doc - [deleted] tisaac/random123 - [deleted] tisaac/sys-fix-realloc - [deleted] tisaac/thplex-makefile-examples - [deleted] tisaac/ts-ex11-amr - [deleted] tisaac/update-p4est - [deleted] tmunson/docs-fix-developer-doc - [deleted] tmunson/kspcg-fix-trust-region-functions - [deleted] tmunson/tao-bqpip-fix-code-and-documentationu
For reference - current list of remote branches Satish ---------- $ git branch -r |wc -l 246 $ git branch -r origin/BarryFSmith/readmemd-created-online-with-bitbucket- 1506004176072 origin/Fande-Kong/fix_dtfe origin/Fande-Kong/fix_dtfe_default_setting origin/Fande-Kong/ksp_only_null_space origin/HEAD -> origin/master origin/adams/zeroDSOR origin/balay/add-dasub-f-interface/maint origin/balay/atpesc-tutorial-2014-bgq origin/balay/atpesc-tutorial-2015-bgq origin/balay/atpesc-tutorial-2016-bgq origin/balay/fix-ctable-hash-again/maint origin/balay/fix-cxx-cmplx-single origin/balay/fix-rebuild-xsdktrilinos origin/balay/fix-superlu_dist-reuse-factornumeric1-maint-backport origin/balay/fix-uninstall origin/balay/giturl-fixes origin/balay/k-fujitsu-f90-v3.6 origin/balay/to-maint-switch-hdf5-build-to-cmake origin/balay/update-elemental-nov-2016 origin/barry/check-no-autodetect-first origin/barry/cleanup-checkclibraries origin/barry/feature-enhanced-binary-viewers origin/barry/fix-gamg-asm-aggs origin/barry/fix-gamg-asm-aggs-donottouch origin/barry/fix-hypre-struct origin/barry/fix-petscviewer-attempt-1 origin/barry/fix-scalapack-pic/maint origin/barry/fix-suffixed-constants-quad origin/barry/fix-threadsafety-mpi-key-value-create origin/barry/fix-xsdk-0.2.0-rc2 origin/barry/force-use-of-ksperrorifnotconverged origin/barry/generate-base-performance-data origin/barry/html origin/barry/improve-secant-linesearch origin/barry/new-test-makefiles origin/barry/newhtml origin/barry/oana/spectral-toy-updates origin/barry/pyjac origin/barry/saws-profile origin/barry/spectral-toy origin/barry/superlu_mt origin/barry/support-dmcreatedomaindecompositionscatters-da- nonperiodic-maint origin/barry/this-is-strange origin/barry/ts-nonnegative-values origin/barry/utilize-hwloc origin/barry/utilize-hwloc-rebased origin/bueler/clean-ex9 origin/dalcinl/add-tsrestart origin/dalcinl/fix-dmplex-draw origin/dalcinl/fix-xaij-spd origin/dalcinl/malloc-coalesced origin/dalcinl/math-isclose origin/dalcinl/ts-adapt-dsp origin/dalcinl/ts-snes origin/damalbel/dmnetwork_nest origin/damalbel/dmnetwork_nest_fieldsplit origin/debo/mat-taij origin/debo/ts-fix-ex31 origin/debo/ts-irk origin/dmay/ksp-cvgtest-normtype-fix origin/emil/add-fortran-ts-pre-post-stage-step/maint origin/emil/fix-ts-dae-rebased-v2 origin/emil/ts-steady-state-ex31 origin/hongzh/add-ell-format origin/hongzh/copy_l2g_stencil origin/hongzh/remove-manual-unrolling origin/hongzh/swe origin/hongzh/symplectic-integrator origin/hongzh/ts-matshell-example origin/hzhang/dmnetwork-couple origin/hzhang/fix-ptaptest origin/hzhang/ksp-fminres origin/hzhang/ksp-minresqlp origin/hzhang/opt-mattransposematmult origin/hzhang/subnetworks-couple origin/irving/fe-scalars origin/irving/snes-ex12-cleanup origin/jed/assembly-perf origin/jed/cray-externc origin/jed/defined-nocpp origin/jed/elbueler-snes-ex5-fixes origin/jed/feature-dmda-section origin/jed/feature-sf-local origin/jed/fix-mat-convert-basic-bs origin/jed/ksp-plugin origin/jed/mat-eigenvalue-cache origin/jed/mat-hash origin/jed/mat-kaij origin/jed/mat-taij origin/jed/mpi-2 origin/jed/next-seaice origin/jed/sr-driver origin/jed/sr-driver4 origin/jed/tao-status-string origin/jed/tap origin/jed/testsrcs-refresh origin/jed/ts-ex11-union origin/jed/ts-heat-plex origin/jed/variadic-malloc origin/jed/vecghostgetvalues origin/john-saws-webosocket-update origin/john/saws-webui-upgrade origin/jose/lapack-check origin/karlrupp/feature-fast-matmatmult origin/karlrupp/feature-optimize-opencl-petscfe origin/karlrupp/feature-pipelined-cg-viennacl origin/karlrupp/feature-viennacl-cuda origin/karlrupp/feature-viennacl-openmp origin/karlrupp/fix-tao-examples origin/karlrupp/fix-viennacl-veccopy origin/karpeev/fix-pc-fieldsplit-reset origin/karpeev/mat-convert-nest-aij-test origin/karpeev/mat-reset origin/klaij/fieldsplit-simple-ex70 origin/knepley/feature-configure-kcomputer origin/knepley/feature-da-repartition origin/knepley/feature-fe-nonaffine origin/knepley/feature-optcontrol-mg origin/knepley/feature-plasma-example origin/knepley/feature-plex-box-mesh origin/knepley/feature-plex-example-nonconforming origin/knepley/feature-plex-nasm origin/knepley/feature-plex-snesvi-example origin/knepley/feature-rigid-bodies origin/knepley/feature-snes-rewrite origin/knepley/feature-spectral-solutions origin/knepley/fix-cohesive-orientation origin/knepley/fix-quadrature-order origin/knepley/ibamr origin/knepley/pylith origin/knepley/swarm origin/madams/ex56params origin/madams/sor-residual origin/madams/sr-driver origin/madams/sr-driver2 origin/madams/sr-driver4 origin/madams/sr1 origin/maint origin/maint-3.2 origin/maint-3.3 origin/maint-3.4 origin/maint-3.5 origin/maint-3.6 origin/maint-3.7 origin/maint-tao-2.2 origin/mark/aij-overlap origin/mark/dm-bs-bug origin/mark/dmplex-generalize-periodicity origin/mark/ex48-jacobian origin/mark/feature-picell origin/mark/mat-fix-scale origin/mark/plex-tuts origin/mark/ts-ex11-mhd origin/master origin/master-tao origin/mlange/feature-plex-case origin/mlange/feature-plex-create-parallel origin/mlange/feature-plex-triangle origin/mlange/fix-adjacency-performance origin/mlange/fix-plex-cas-tests origin/mlange/fix-plex-hex-mesh origin/mlange/plex-create-parallel origin/mlange/plex-distributed-overlap origin/mlange/plex-hybrid-hdf5 origin/mlange/plex-redistribute origin/mlange/plex-sfc-reordering origin/mlange/plex-vertex-partitioning origin/mlange05/fix-gmsh-coordinates origin/next origin/next-apr-2016 origin/next-jun-2015 origin/next-jun-2017 origin/next-may-2016 origin/next-oct-2014 origin/next-tmp origin/oana/spectral-toy origin/paulmullowney/aijcusp-ellpack-fix origin/pefarrell/dmshell-asm origin/pefarrell/nasm-fixes origin/peller/threadcomm origin/pr118/asmunder/DMDA-fortran-example/master origin/pr478/pfarrell/feature-dmplex-adapt origin/pr600/dmeiser/feature-examples-newmethod/master origin/prbrune/matcoloring-creategraph origin/prbrune/matcoloring-minpack origin/prbrune/matcoloring-misimprovement origin/prbrune/matcoloring-zoltan origin/prbrune/pcgamg-bootstrap origin/prbrune/pcgamg-classicalbootstrap origin/prbrune/pcgamg-cr origin/prbrune/sf-examplefix origin/prbrune/snes-ex19vtkoutput origin/prbrune/snes-fasadditive origin/prbrune/zoltanupdate origin/psanan/ksp-tutorial-ex60-fixes origin/psanan/ts-bz-examples origin/psanan/ts-multiscale origin/psanan/ts-rhs-partitions origin/psanan/ts-tests origin/psanan/vec-mtdot-fix origin/sarich/feature-submatrixfree origin/sarich/feature-tao-pounders-jacobian origin/sarich/fix-alquimia-static origin/sarich/mira origin/sarich/snesvi-subvec-options origin/sarich/tao-pounders-add-corr-test origin/scott/test-harness-debugger origin/scott/test-harness-installtest origin/scott/update-dm-dt-output origin/shri/FTRTDS-project origin/shri/dmnetwork-subnetworks origin/shri/ts-dae-semi-explicit origin/shri/ts-powergrid origin/stefano_zampini/feature-continuousadjoint origin/stefano_zampini/feature-newmattype-elementlist origin/stefano_zampini/new-elemental-interface origin/tisaac/buildsystem-feature-parallel origin/tisaac/buildsystem-feature-subst-link-flags origin/tisaac/config-fix-petsc-py origin/tisaac/dm-project-function-label origin/tisaac/dt-feature-vectur-quadrature origin/tisaac/dual-space-get-traces origin/tisaac/feature-dmfield origin/tisaac/feature-fe-integrate-nonaffine origin/tisaac/feature-gamg-compose-graph origin/tisaac/feature-picell origin/tisaac/feature-plex-example-nonconforming origin/tisaac/feature-seqaij-get-submat-row-unordered origin/tisaac/feature-seqaij-submat-col-unsorted origin/tisaac/feature-test-maxiter-filter origin/tisaac/fix-gamg-set-coordinates origin/tisaac/gamg-more-info origin/tisaac/knepley/feature-composable-callbacks origin/tisaac/ksp-fix-cheby-pc-handling origin/tisaac/master-merge-mark-snesex56 origin/tisaac/moab-update origin/tisaac/pc-pbjacobi-vec-get-array-read origin/tisaac/petsc-next-upstream origin/tisaac/plex-descriptive-debug origin/tisaac/plex-feature-vec-get-star origin/tisaac/plex-fv-without-ghosts origin/tisaac/warn-next-upstream origin/tmunson/tao-feature-hessian-lagrangian origin/tmunson/tao-fix-leastsquares-tests origin/tmunson/tao-pounders-fix-code origin/vi/snes-newtonaugas $
participants (1)
Balay, Satish
