Re: [petsc-dev] Generality of VecScatter
On Sat, Nov 26, 2011 at 14:25, Mark F. Adams <[email protected]>wrote:
So each MPI_Get initiates a message and you pack up a message with an array of remote pointers or something?
MPI_Get() has an MPI_Datatype for the remote process. That describes where in the remote buffer the values should be gotten from. This is much like how VecScatter can operate on just part of a Vec.
It sounds like you are saying that you have an auxiliary arrays of remote global indices for each processor that you communicate with and your broadcast code looks like:
for all 'proc' that I talk to
for all proc that I _need_ an update from, I don't know or care who needs an update from me
i = 0 for all 'v' on proc list if v.state == not-done
I didn't think we would bother with communicating only those values that were actually updated. Since this should converge in just a few rounds, I figured that we would just update all ghost points. Note that communicating the metadata to send only those values that have actually changed may make the algorithm less latency-tolerant.
data[i++] = [ &v.state, v.id, STATE ] // vague code here... endif endfor MPI_Get(proc,i,data) endfor
I thought we would skip any loop over vertices and just one-time setup: remotes = {} for each ghost vertex v: remotes[v.owner_rank] += 1 # add/increment entry for this rank nremotes = remotes.size build MPI_Datatype their_datatype[nremotes] (using the remote index stored for each ghosted vertex) and my_datatype[nremotes] (using the sequential locations of the ghost vertices in my array) for each rank in remotes, implement as one loop over ghost vertices communication in each round: MPI_Win_fence(0, window) for (r,rank) in remotes: MPI_Get(my_ghosted_status_array, 1, my_datatype[r], rank, 0, 1, their_datatype[r], window) MPI_Win_fence(0, window) All the packing and unpacking is done by the implementation and I never traverse vertices in user code.
participants (1)
Jed Brown
