Re: [petsc-dev] broken stuff in next for many days
On Apr 21, 2018, at 6:38 PM, Balay, Satish <[email protected]> wrote:
On Sat, 21 Apr 2018, Václav Hapla wrote:
Sorry Barry, that's my fault.
Thanks a lot Satish for the quick fix with !trilinos. Hope it works now.
I think the chaco partitioner should be definitely replaced by simple it these tests as Matt suggested. But I will rather push it within a separate PR since it extends the tested archs (by removing chaco and !trilinos requirements) so some previously unseen issues might appear theoretically.
Yes - any changes should be a new PR.
It would be good to figure out exactly where the difference comes form [wrt chaco from trilinos vs separate install of chaco - or some other interaction from trilinos]
Different random numbers being generated?
and we could keep chaco tests - and tailor them appropriately with '!trilinos' or have multipe outout file [i.e _alt.out format] for chaco tests - if thats appropriate.
If both sets are correct than an _alt file is better than !trilinos in the long run. Barry
Satish
participants (1)
Smith, Barry F.
