Re: [petsc-dev] Error on Fugaku
I have this building now. Do you know anything about OpenMP? I can add --with-openmp That should get Kokkos to be made with OpenMP. Should PETSc deal with the compilers correctly? Thanks, Mark On Wed, Apr 14, 2021 at 1:45 PM Mark Adams <[email protected]> wrote:
Thanks, If you feel inspired you could try Kokkos :|| I am in a parking lot waiting for my daughter but can try this when I get home, Thanks again, Mark
On Wed, Apr 14, 2021 at 1:33 PM Satish Balay <[email protected]> wrote:
I think I allocated a single node - and did the build on it.
Now I'm getting an error - don't know what changed..
login6$ pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L "rscgrp=eap-int" -L "elapse=1:00:00" --sparam "wait-time=600" [ERR.] PJM 0059 pjsub rscgrp=eap-int is disabled.
Ok - the following worked..
login6$ pjsub --interact -L "node=1" -L "rscunit=rscunit_ft01" -L "elapse=1:00:00" --sparam "wait-time=600" [INFO] PJM 0000 pjsub Job 6301572 submitted. [INFO] PJM 0081 .connected. [INFO] PJM 0082 pjsub Interactive job 6301572 started. [a04201@j31-3110s petsc]$
Ok - trying this build now.
[a04201@j31-3110s petsc]$ cat ~/petsc.save/arch-arm/lib/petsc/conf/reconfigure-arch-arm.py #!/usr/bin/python3 if __name__ == '__main__': import sys import os sys.path.insert(0, os.path.abspath('config')) import configure configure_options = [ '--with-blaslapack-lib=-lfjlapack', '--with-debugging=0', 'CC=mpifcc', 'CXX=mpiFCC', 'FC=mpifrt', 'PETSC_ARCH=arch-arm', ] configure.petsc_configure(configure_options) [a04201@j31-3110s petsc]$ ~/petsc.save/arch-arm/lib/petsc/conf/reconfigure-arch-arm.py --download-p4est --download-zlib <snip> p4est: Includes: -I/vol0004/ra010009/a04201/petsc/arch-arm/include Library: -Wl,-rpath,/vol0004/ra010009/a04201/petsc/arch-arm/lib -L/vol0004/ra010009/a04201/petsc/arch-arm/lib -lp4est -lsc
Ok - this worked for me.
Satish
On Wed, 14 Apr 2021, Mark Adams wrote:
Do you recall what nodes you use to build on a "compute" node, to avoid cross compilation?
On Wed, Apr 14, 2021 at 12:08 PM Satish Balay <[email protected]> wrote:
looks like p4est cannot be cross-compiled.
Satish
I get this error with p4est on Fugaku. It is a Fortran error. Odd. Mark
participants (1)
Mark Adams
