Re: [petsc-dev] How does this compare...
I dug in a little deeper, and I recommend reading their previous paper: http://arxiv.org/abs/1011.3534 That paper actually _does_ mention the connection to H-matrix algebra: "SpAMM is similar to the H-matrix algebra of Hackbusch and co-workers, where off-diagonal sub-matrices are treated as reduced rank factorizations (truncated SVD), typically structured and grouped to reflect properties of the underlying operators. For problems with rapid decay, truncated SVD may behave in a similar way to simple dropping schemes. SpAMM is different than the H-matrix algebra as it achieves separation uniquely in the product space and does not rely on a reduced complexity representation of matrices. For very slow decay, the H-matrix algebra may certainly offer a path for intractable problems for which SpAMM is ineffective." So it seems that the claim is that SpAMM might be more computationally efficient than H-matrices for fast decay, but ineffective otherwise. Either way, I don't think it's going to help with classical parallel sparse matrix-matrix multiplication. Jack On Wed, Mar 28, 2012 at 10:28 PM, Jack Poulson <[email protected]>wrote:
Actually, please excuse my misreading. The quoted 2-3x speedup was versus itself due to hardware prefetch, so it does appear to be asymptotically better than SGEMM (they quote the crossover at n ~= 1000).
Jack
On Wed, Mar 28, 2012 at 10:23 PM, Jack Poulson <[email protected]>wrote:
I just took a look at the paper and, after reading a bit, I am baffled that there are no citations of the H-matrix literature (Ctrl+F "Hackbusch" turns up nothing...). The paper seems to be in a similar spirit as the well-known H-matrix/H-matrix multiplication algorithms, which take O(N log^2 N) work, for O(1) ranks, but using truncation instead of low-rank approximations in clusters. Since only factors of 2-3x are reported versus SGEMM, which is O(N^3), that tells you that this algorithm (or, at least, its implementation) is O(N^3).
I do not think a comparison can be drawn to sparse matrix-matrix multiply algorithms. I believe Gilbert and Buluc have the most recent publication on parallel sparse mat-mat. I have done some work on parallel H-matrix/H-matrix multiplication (the code is here: http://bitbucket.org/poulson/dmhm), but I haven't pushed the paper out the door yet. See http://www.ices.utexas.edu/~poulson/slides/DMHM.pdffor the talk I gave on it. I suspect that the ideas from parallel H-matrix/H-matrix multiplication could be used to generate a communication-efficient sparse mat-mat if it is okay to generate the result in a more general data-sparse form (i.e., low rank blocks) rather than specifically as explicitly classically sparse.
Jack
On Wed, Mar 28, 2012 at 10:07 PM, Hong Zhang <[email protected]> wrote:
Entire paper discusses SpAMM, and compares with SGEMM. Sorry, I do not see anything about SpMV. Hong
On Wed, Mar 28, 2012 at 9:52 PM, Matthew Knepley <[email protected]>wrote:
On Wed, Mar 28, 2012 at 9:39 PM, Hong Zhang <[email protected]> wrote:
Matt:
to the new scalable MatMatMult() that is done in PETSc? Is it possible to even compare the flop rates sensibly?
"An Optimized Sparse Approximate Matrix Multiply" computes Approximate matrix product for matrices with decay ^^^^^^^^^^^^ ^^^^^^^^^^ It is for special application in chemistry(?), not applicable for general sparse matrix product. No comparison can be drawn to petsc's C=A*B.
This is the wrong conclusion. What he does is sparsify the result, so he is computing SOME sort of sparse matrix-vector product. The question is:
Does his SpMV use the same algorithm as PETSc?
That is why I asked.
Matt
Hong
This is what Jeff is planning on using in his SciDAC.
Matt
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Jack Poulson
