Re: [petsc-dev] Intel compilers + CUDA
--compiler-bindir <directory> (-ccbin) Specify the directory in which the compiler executable (Microsoft Visual Studion cl, or a gcc derivative) resides. By default, this executable is expected in the current executable search path. <<<<<<<<
It says it will look for the default compiler in the specified path - and doesn't mention that it can switch the compiler. Ah - the manpage is misleading.. Looks like '--ccbin icc' works.. balay@bb30:~/junk>nvcc -v -ccbin icc sizeof.c #$ _SPACE_= #$ _CUDART_=cudart #$ _HERE_=/usr/local/cuda/bin #$ _THERE_=/usr/local/cuda/bin #$ _TARGET_SIZE_=64 #$ TOP=/usr/local/cuda/bin/.. #$ LD_LIBRARY_PATH=/usr/local/cuda/bin/../lib:/usr/local/cuda/bin/../extools/lib:/soft/intel/11.0.081/lib/intel64:/soft/intel/11.0.081/lib/intel64:/usr/local/cuda/lib64:/usr/local/cuda/lib64 #$ PATH=/usr/local/cuda/bin/../open64/bin:/usr/local/cuda/bin:/soft/intel/11.0.081/bin/intel64:/soft/intel/11.0.081/bin/intel64:/usr/mpi/gcc/mvapich2-1.5/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/cuda/bin:/usr/local/cuda/bin #$ INCLUDES="-I/usr/local/cuda/bin/../include" "-I/usr/local/cuda/bin/../include/cudart" #$ LIBRARIES= "-L/usr/local/cuda/bin/../lib64" -lcudart #$ CUDAFE_FLAGS= #$ OPENCC_FLAGS= #$ PTXAS_FLAGS= #$ icc -c -x c "-I/usr/local/cuda/bin/../include" "-I/usr/local/cuda/bin/../include/cudart" -m64 -o "/tmp/tmpxft_00000199_00000000-1_sizeof.o" "sizeof.c" #$ icpc -m64 -o "a.out" -Wl,--start-group "/tmp/tmpxft_00000199_00000000-1_sizeof.o" "-L/usr/local/cuda/bin/../lib64" -lcudart -Wl,--end-group balay@bb30:~/junk> So '--with-cc=icc' --with-nvcc='nvcc --ccbin icc' should work.. Will check.. Satish On Fri, 24 Feb 2012, John Fettig wrote:
Some time ago I asked about using icc with nvcc. You can use icc with nvcc by passing it as an argument:
nvcc -ccbin /path/to/icc
Has anybody tried building PETSc with CUDA this way?
John
participants (1)
Satish Balay
