Re: Should PetscObjectName be collective?
On Mon, Nov 16, 2009 at 10:49 AM, Jed Brown <[email protected]> wrote:
Since it is not collective, the names can get out of sync, even with "reasonable" usage. Consider a case where rank 0 views a serial Vec (say with the Matlab viewer), and then a parallel Vec (e.g. to HDF5). The result would either be deadlock (with collective IO) or a file where Vec_0 contains all but rank 0's part, and Vec_1 contains only rank 0's part (and an HDF5 error once another vector is viewed because the Vec_1 dataspace cannot be created if it already exists).
Is it reasonable to make PetscObjectName (and necessary dependents) collective where it performs this?
MPI_Allreduce(MPI_IN_PLACE,&counter,1,MPI_INT,MPI_MAX,obj->comm);
And what about VecView() of serial objects on two different processes? What about parallel Vec's on subcommunicators of COMM_WORLD? -- Lisandro Dalcín --------------- Centro Internacional de Métodos Computacionales en Ingeniería (CIMEC) Instituto de Desarrollo Tecnológico para la Industria Química (INTEC) Consejo Nacional de Investigaciones Científicas y Técnicas (CONICET) PTLC - Güemes 3450, (3000) Santa Fe, Argentina Tel/Fax: +54-(0)342-451.1594
participants (1)
Lisandro Dalcin
