Re: [petsc-dev] MatCreateVecs interface
On Jun 26, 2015, at 7:28 AM, Stefano Zampini <[email protected]> wrote:
I merged the fix for MatCreateVecs into next
https://bitbucket.org/petsc/petsc/commits/248f4e93fc838f918a85fe2b6cf6cc3494...
If we agree on MatGetDefaultVecType, I will create a new branch for it Maybe we don’t need a new function, but just store the default vec type into Mat (defaulting to VECSTANDARD) and then have MPICUSP and others override the default when their are instantiated. What do you think?
Better to have a Set and Get because one must free the old string and PetscStrallocpy() the new string and if each mat type is doing this manually likely someone will forget the free or cut and paste wrong. Barry
Stefano
On Jun 25, 2015, at 8:10 PM, Stefano Zampini <[email protected]> wrote:
Yes. With this approach, only MatNest will need a specialized getvecs operation and we can get rid of the others.
On Jun 25, 2015, at 7:06 PM, Barry Smith <[email protected]> wrote:
On Jun 25, 2015, at 12:32 PM, Stefano Zampini <[email protected]> wrote:
pushed a fix https://bitbucket.org/petsc/petsc/commits/ae287a2e7a141494f7c41f9dd537addb63...
However, it appears that the functions below for CUSP, CUSPARSE and VIENNACL are mere copies of the interface. What about defining the type of the Vec in the interface and get rid of these?
What do you mean by "the type of Vec in the interface"? Do you mean have a method such as
MatGetDefaultVecType(mat,const VecType *vtype);
that defines the default vector type compatible with the matrix? So we could have
#undef __FUNCT__ #define __FUNCT__ "MatCreateVecs_Default" PetscErrorCode MatCreateVecs_Default(Mat mat,Vec *right,Vec *left) { PetscErrorCode ierr; PetscInt rbs,cbs; const VecType vtype;
PetscFunctionBegin; ierr = MatGetDefaultVecType(mat,&vtype);CHKERRQ(ierr); ierr = MatGetBlockSizes(mat,&rbs,&cbs);CHKERRQ(ierr); if (right) { ierr = VecCreate(PetscObjectComm((PetscObject)mat),right);CHKERRQ(ierr); ierr = VecSetSizes(*right,mat->cmap->n,PETSC_DETERMINE);CHKERRQ(ierr); ierr = VecSetBlockSize(*right,cbs);CHKERRQ(ierr); ierr = VecSetType(*right,vtype);CHKERRQ(ierr); ierr = VecSetLayout(*right,mat->cmap);CHKERRQ(ierr); } if (left) { ierr = VecCreate(PetscObjectComm((PetscObject)mat),left);CHKERRQ(ierr); ierr = VecSetSizes(*left,mat->rmap->n,PETSC_DETERMINE);CHKERRQ(ierr); ierr = VecSetBlockSize(*left,rbs);CHKERRQ(ierr); ierr = VecSetType(*left,vtype);CHKERRQ(ierr); ierr = VecSetLayout(*left,mat->rmap);CHKERRQ(ierr); } PetscFunctionReturn(0); }
or something else?
Barry
src/mat/impls/aij/mpi/mpicusp/mpiaijcusp.cu: A->ops->getvecs = MatCreateVecs_MPIAIJCUSP; src/mat/impls/aij/mpi/mpicusparse/mpiaijcusparse.cu: A->ops->getvecs = MatCreateVecs_MPIAIJCUSPARSE; src/mat/impls/aij/mpi/mpiviennacl/mpiaijviennacl.cxx: A->ops->getvecs = MatCreateVecs_MPIAIJViennaCL; src/mat/impls/aij/seq/seqcusp/aijcusp.cu: B->ops->getvecs = MatCreateVecs_SeqAIJCUSP; src/mat/impls/aij/seq/seqcusparse/aijcusparse.cu: B->ops->getvecs = MatCreateVecs_SeqAIJCUSPARSE; src/mat/impls/aij/seq/seqviennacl/aijviennacl.cxx: B->ops->getvecs = MatCreateVecs_SeqAIJViennaCL;
Stefano
On Jun 25, 2015, at 4:34 PM, Barry Smith <[email protected]> wrote:
I think you are right, go ahead and make a pull request or send a patch
Barry
On Jun 25, 2015, at 9:43 AM, Stefano Zampini <[email protected]> wrote:
Why the current interface in MatCreateVecs requires that a matrix has been already either allocated or setup ? Shouldn’t be enough to check if the layout has been already setup?
Stefano
participants (1)
Barry Smith
