Re: [petsc-dev] bin/sh error while running tests
On 20 Jan 2021, at 12:11 PM, Stefano Zampini <[email protected]> wrote:
This is an issue with the default shell used by the makefile. Below is my fix. We should probably have a CI machine that checks for these shell-related errors.
I second this. Just spent too much time finding this other bash-ism in gmakefile.test… https://gitlab.com/petsc/petsc/-/commit/e4b11943e93779206a0e5f2091646de2e86b... <https://gitlab.com/petsc/petsc/-/commit/e4b11943e93779206a0e5f2091646de2e86b10e3#551c4017403b9179c385d5600f43348b6288a751> 2021-01-20T11:21:22.5942304Z /usr/bin/sh: 1: test: false: unexpected operator 2021-01-20T11:21:22.5981176Z make: *** [gmakefile.test:270: check-test-errors] Error 1 Thanks, Pierre
diff --git a/gmakefile.test b/gmakefile.test index c38e37f..ffd7bdb 100644 --- a/gmakefile.test +++ b/gmakefile.test @@ -379,10 +379,11 @@ starttime: pre-clean $(libpetscall) @$(eval STARTTIME := $(shell date +%s))
report_tests: starttime $(TESTTARGETS) +ifeq ($(showreport),true) @$(eval ENDTIME := $(shell date +%s)) - -@if test ${showreport} == "true"; then elapsed_time=$$(($(ENDTIME)- $(STARTTIME))) && \ - $(PYTHON) $(CONFIGDIR)/report_tests.py -m $(MAKE) -d $(TESTDIR)/counts -t 5 -e $${elapsed_time};\ - fi + elapsed_time=$$(($(ENDTIME)- $(STARTTIME))) && \ + $(PYTHON) $(CONFIGDIR)/report_tests.py -m $(MAKE) -d $(TESTDIR)/counts -t 5 -e $${elapsed_time}; +endif
Il giorno mar 19 gen 2021 alle ore 20:41 Scott Kruger <[email protected] <mailto:[email protected]>> ha scritto:
I can't reproduce this with the latest master:
hip 1261: git pull Already up to date. hip 1262: make -f gmakefile.test test search='notatest' Using MAKEFLAGS: -- search=notatest hip 1263:
On 1/19/21 8:19 AM, Stefano Zampini wrote:
Just rebased over latest master and got this
zampins@vulture:~/Devel/petsc$ make -f gmakefile.test test search='notatest' Using MAKEFLAGS: -- search=notatest /bin/sh: 1: test: false: unexpected operator
-- Stefano
-- Tech-X Corporation [email protected] <mailto:[email protected]> 5621 Arapahoe Ave, Suite A Phone: (720) 466-3196 Boulder, CO 80303 Fax: (303) 448-7756
-- Stefano
participants (1)
Pierre Jolivet
