Re: [petsc-dev] Regarding an error
On Tue, Feb 28, 2012 at 07:18, Chen S <[email protected]> wrote:
I've built it with the fixed files and got the following errors (attached)
These line numbers don't match up at all and the errors look quite nonsensical. This smells of a Windows file encoding issue. C:\cygwin\home\PETSC-~4\src\mat\coarsen\impls\mis\mis.c(1) : error C2059: syntax error : '<' C:\cygwin\home\PETSC-~4\src\mat\coarsen\impls\mis\mis.c(10) : error C2018: unknown character '0x40' C:\cygwin\home\PETSC-~4\src\mat\coarsen\impls\mis\mis.c(48) : error C2014: preprocessor command must start as first nonwhite space mis.c line 1 is an empty line, line 2 is definitely valid C: #include <private/matimpl.h> /*I "petscmat.h" I*/ ASCII 0x40 is "@" which does not even appear in that file. There is not a preprocessor directive anywhere near line 48.
participants (1)
Jed Brown
