Re: [petsc-dev] testharness failure Exception: Keyword: redirect_file from: redirect_file: ex1_1.tmp is not valid
Scott, There is a problem. Somehow you are generating a ton of new_ex*.c files and then testparse.py is crapping out on them? I see some weird stuff with these files but cannot tell when they are made and why they exist. config/gmakegentest.py: #if not exfile.startswith("new_"+"ex"): continue config/testparse.py: new_pos = sl.instream.tell() config/testparse.py: block = striptest[last_pos:new_pos] config/testparse.py: last_pos = new_pos config/testparse.py: bn=re.sub("new_","",basename) config/testparse.py: for test_file in sorted(glob.glob("new_ex*.*")):
On Dec 12, 2021, at 10:32 PM, Barry Smith <[email protected]> wrote:
Looks like it is coming from some old .c files that I had lying around that are not in the repository.
I will push a commit that prints the offending file name to make the cause easier to track down in the future
Barry
On Dec 12, 2021, at 6:09 PM, kruger Scott <[email protected]> wrote:
I'm baffled and unable to reproduce. Can you give me your configure.log to help reproduce?
Scott
On 2021-12-12 17:40, Barry Smith did write:
Scott,
In the branch barry/2021-11-04/add-dmplex-vecghost which was just rebased on main I get
/usr/local/opt/[email protected]/bin/python3.9 ./config/gmakegen.py --petsc-arch=arch-add-dmplex-vecghost /usr/local/opt/[email protected]/bin/python3.9 /Users/barrysmith/Src/petsc/config/gmakegentest.py --petsc-dir=/Users/barrysmith/Src/petsc --petsc-arch=arch-add-dmplex-vecghost --testdir=./arch-add-dmplex-vecghost/tests Traceback (most recent call last): File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 1089, in <module> main(petsc_dir=opts.petsc_dir, petsc_arch=opts.petsc_arch, File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 1060, in main dataDict=pEx.walktree(os.path.join(pEx.srcdir)) File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 924, in walktree self.genPetscTests(root,dirs,files,dataDict) File "/Users/barrysmith/Src/petsc/config/gmakegentest.py", line 897, in genPetscTests dataDict[root].update(testparse.parseTestFile(fullex,0)) File "/Users/barrysmith/Src/petsc/config/testparse.py", line 542, in parseTestFile testDict[basename]=parseTests(testString,srcfile,fileNums,verbosity) File "/Users/barrysmith/Src/petsc/config/testparse.py", line 498, in parseTests testnames,subdicts=parseTest(test,srcfile,verbosity) File "/Users/barrysmith/Src/petsc/config/testparse.py", line 426, in parseTest if not var in acceptedkeys: raise Exception("Keyword: "+var+" from: "+line+" is not valid") Exception: Keyword: redirect_file from: redirect_file: ex1_1.tmp is not valid make: *** [gmakefile.test:97: arch-add-dmplex-vecghost/tests/testfiles] Error 1
How to track down the problem? Is it due to a bad rule from some file (which file, could that be printed?)
-- Scott Kruger Tech-X Corporation [email protected] 5621 Arapahoe Ave, Suite A Phone: (720) 466-3196 Boulder, CO 80303 Fax: (303) 448-7756
participants (1)
Barry Smith
