Re: [petsc-dev] lots o' dead code in BuildSystem
On Oct 1, 2014, at 5:31 AM, Matthew Knepley <[email protected]> wrote:
Lots of this is just unused code paths in that particular configure. However, we can probably eliminate the 'build' directory, BiudlSystem.sourceDatabase
Humm, you seem to use sourceDatabase all over the place, I need to put it back Satish I need you help. How do I roll back my last two commits? commit 35c428b1b3dc6b69b2fab79779ef81d3231bc7a0 Author: Barry Smith <[email protected]> Date: Wed Oct 1 11:32:32 2014 -0500 removed dead CHUD code commit 2cb0f3eae6eb618a9defff89b420aead8b127264 Author: Barry Smith <[email protected]> Date: Wed Oct 1 09:56:26 2014 -0500 removed more dead BuildSystem code I want to get back here on the branch!
and PETSc.FEM
Matt
On Tue, Sep 30, 2014 at 11:11 PM, Barry Smith <[email protected]> wrote:
~/Src/petsc barry/remove-sidl $ Vulture config config/builder.py:605: Unused variable 'comparsion' config/builder.py:639: Unused function 'extractTests' config/builder.py:663: Unused attribute 'cmd' config/builder.py:684: Unused attribute 'ret' config/builder.py:684: Unused attribute 'store' config/builder.py:704: Unused function 'updateNode' config/builder.py:1093: Unused attribute 'memAlign' config/builder.py:1250: Unused attribute 'operationFailed' config/builder.py:1290: Unused function 'compileCUDA' config/builder.py:1293: Unused function 'compileCxx' config/builder.py:1296: Unused function 'compileFortran' config/builder.py:1342: Unused function 'compileCParallel' config/builder.py:1345: Unused function 'compileCxxParallel' config/builder.py:1348: Unused function 'compileFortranParallel' config/builder.py:1374: Unused function 'expandArchive' config/builder.py:1677: Unused function 'checkTestOutput' config/builder.py:1680: Unused function 'checkTestOutputSolver' config/builder.py:1777: Unused function 'buildEtags' config/BuildSystem/args.py:69: Unused attribute '_setCommandLine' config/BuildSystem/build/buildGraph.py:71: Unused function 'removeSubgraph' config/BuildSystem/build/compile/C.py:6: Unused attribute 'usingC' config/BuildSystem/build/compile/Cxx.py:6: Unused attribute 'usingCxx' config/BuildSystem/build/compile/F90.py:6: Unused attribute 'usingF90' config/BuildSystem/build/fileset.py:181: Unused class 'RootedExtensionFileSet' config/BuildSystem/build/fileState.py:61: Unused class 'GenericTag' config/BuildSystem/build/fileState.py:106: Unused class 'Update' config/BuildSystem/build/framework.py:27: Unused attribute 'directories' config/BuildSystem/build/framework.py:78: Unused function 'makeSourceDBPathsAbsolute' config/BuildSystem/build/framework.py:87: Unused function 'makeSourceDBPathsRelative' config/BuildSystem/build/framework.py:103: Unused variable 'newTmp' config/BuildSystem/build/framework.py:177: Unused function 't_activate' config/BuildSystem/build/framework.py:184: Unused function 't_deactivate' config/BuildSystem/build/framework.py:195: Unused function 't_configure' config/BuildSystem/build/framework.py:259: Unused function 't_compile' config/BuildSystem/build/framework.py:264: Unused function 't_compilePrograms' config/BuildSystem/build/framework.py:271: Unused function 't_install' config/BuildSystem/build/framework.py:290: Unused function 't_uninstall' config/BuildSystem/build/framework.py:306: Unused function 't_citool' config/BuildSystem/build/framework.py:312: Unused function 't_push' config/BuildSystem/build/framework.py:321: Unused function 't_pull' config/BuildSystem/build/framework.py:331: Unused function 't_makeStamp' config/BuildSystem/build/framework.py:339: Unused function 't_default' config/BuildSystem/build/framework.py:343: Unused function 't_printTargets' config/BuildSystem/build/framework.py:357: Unused function 't_purge' config/BuildSystem/build/framework.py:374: Unused function 't_update' config/BuildSystem/build/processor.py:341: Unused class 'DirectoryArchiver' config/BuildSystem/build/processor.py:386: Unused class 'Archiver' config/BuildSystem/build/processor.py:460: Unused class 'ImportSharedLinker' config/BuildSystem/build/processor.py:507: Unused class 'LibraryAdder' config/BuildSystem/build/transform.py:41: Unused class 'Filter' config/BuildSystem/build/transform.py:59: Unused class 'Remover' config/BuildSystem/build/transform.py:80: Unused class 'Consolidator' config/BuildSystem/config/base.py:189: Unused function 'addArgumentSubstitution' config/BuildSystem/config/base.py:279: Unused function 'getExecutables' config/BuildSystem/config/base.py:658: Unused function 'splitIncludes' config/BuildSystem/config/compile/processor.py:70: Unused function 'pushRequiredFlags' config/BuildSystem/config/compile/processor.py:73: Unused function 'popRequiredFlags' config/BuildSystem/config/compilers.py:21: Unused attribute 'cRestrict' config/BuildSystem/config/compilers.py:22: Unused attribute 'cxxRestrict' config/BuildSystem/config/framework.py:366: Unused function 'updatePackageDependencies' config/BuildSystem/config/framework.py:465: Unused function 'addSubstitutionFile' config/BuildSystem/config/framework.py:938: Unused attribute '_configured' config/BuildSystem/config/package.py:61: Unused attribute 'double' config/BuildSystem/config/package.py:62: Unused attribute 'complex' config/BuildSystem/config/package.py:63: Unused attribute 'requires32bitint' config/BuildSystem/config/package.py:94: Unused attribute 'openmpi' config/BuildSystem/config/package.py:542: Unused variable 'foundLibrary' config/BuildSystem/config/package.py:543: Unused variable 'foundHeader' config/BuildSystem/config/packages/cuda.py:24: Unused attribute 'ThrustVersionStr' config/BuildSystem/config/packages/cuda.py:25: Unused attribute 'CUSPVersionStr' config/BuildSystem/config/packages/MPI.py:46: Unused attribute 'shared' config/BuildSystem/config/packages/MPI.py:48: Unused attribute 'commf2c' config/BuildSystem/config/packages/MPI.py:49: Unused attribute 'commc2f' config/BuildSystem/config/packages/MPI.py:181: Unused attribute 'haveFinalized' config/BuildSystem/config/packages/MPI.py:184: Unused attribute 'haveInPlace' config/BuildSystem/config/packages/MPI.py:188: Unused attribute 'haveTypeCreateStruct' config/BuildSystem/config/packages/MPI.py:193: Unused attribute 'haveCommCreateErrhandler' config/BuildSystem/config/packages/MPI.py:198: Unused attribute 'haveCommSetErrhandler' config/BuildSystem/config/packages/MPI.py:410: Unused attribute 'havef90module' config/BuildSystem/config/packages/mpi4py.py:14: Unused attribute 'numpy' config/BuildSystem/config/packages/mpi4py.py:22: Unused variable 'pp' config/BuildSystem/config/packages/mpi4py.py:24: Unused variable 'apple' config/BuildSystem/config/packages/SuperLU_MT.py:12: Unused attribute 'worksonWindows' config/BuildSystem/config/packages/Triangle.py:28: Unused variable 'installmakeinc' config/BuildSystem/config/python.py:12: Unused attribute 'isShared' config/BuildSystem/config/regression/frameworkTest.py:10: Unused class 'FrameworkTest' config/BuildSystem/config/regression/frameworkTest.py:42: Unused function 'testEmptyConfigure' config/BuildSystem/config/regression/frameworkTest.py:47: Unused function 'testLogName' config/BuildSystem/config/regression/frameworkTest.py:54: Unused function 'testFullDefaultConfigure' config/BuildSystem/config/regression/shellTest.py:6: Unused class 'ShellTest' config/BuildSystem/config/regression/shellTest.py:14: Unused function 'testTimeout' config/BuildSystem/config/setCompilers.py:22: Unused attribute 'usedMPICompilers' config/BuildSystem/config/setCompilers.py:622: Unused attribute 'compilerVersionCUDA' config/BuildSystem/config/setCompilers.py:997: Unused attribute 'usePIC' config/BuildSystem/config/setCompilers.py:1020: Unused attribute 'isPIC' config/BuildSystem/config/setCompilers.py:1197: Unused attribute 'staticLinker' config/BuildSystem/config/setCompilers.py:1287: Unused function 'addLinkerFlag' config/BuildSystem/config/setCompilers.py:1373: Unused attribute 'staticLibrary' config/BuildSystem/config/setCompilers.py:1374: Unused attribute 'sharedLibrary' config/BuildSystem/config/setsBackport.py:454: Unused function 'union_update' config/BuildSystem/config/setsBackport.py:464: Unused function 'intersection_update' config/BuildSystem/config/setsBackport.py:541: Unused function 'discard' config/BuildSystem/config/setsOrdered.py:547: Unused function 'updateDuplicate' config/BuildSystem/config/setsOrdered.py:633: Unused class 'SetsTest' config/BuildSystem/config/setsOrdered.py:634: Unused function 'testOrdering' config/BuildSystem/config/setsOrdered.py:640: Unused function 'testUniqueness' config/BuildSystem/config/setsOrdered.py:646: Unused function 'testOrder' config/BuildSystem/config/sourceControl.py:31: Unused attribute 'gitversion' config/BuildSystem/config/sourceControl.py:42: Unused attribute 'hgversion' config/BuildSystem/config/sourceControl.py:51: Unused attribute 'cvxversion' config/BuildSystem/config/sourceControl.py:60: Unused attribute 'svnversion' config/BuildSystem/config/types.py:128: Unused function 'checkFortranStar' config/BuildSystem/maker.py:33: Unused function 'getMake' config/BuildSystem/maker.py:232: Unused class 'BasicMake' config/BuildSystem/nargs.py:5: Unused function 'getInteractive' config/BuildSystem/nargs.py:46: Unused function 'setTemporary' config/BuildSystem/nargs.py:144: Unused function 'getKey' config/BuildSystem/nargs.py:206: Unused class 'ArgFuzzyBool' config/BuildSystem/nargs.py:274: Unused class 'ArgReal' config/BuildSystem/nargs.py:390: Unused class 'ArgExecutable' config/BuildSystem/RDict.py:269: Unused function 'hasType' config/BuildSystem/RDict.py:541: Unused function 'handle' config/BuildSystem/retrieval.py:123: Unused function 'ftpRetrieve' config/BuildSystem/retrieval.py:127: Unused function 'httpRetrieve' config/BuildSystem/retrieval.py:131: Unused function 'fileRetrieve' config/BuildSystem/retrieval.py:135: Unused function 'svnRetrieve' config/BuildSystem/retrieval.py:147: Unused function 'bkUpdate' config/BuildSystem/retrieval.py:217: Unused function 'retrieve' config/BuildSystem/retrieval.py:239: Unused function 'removeRoot' config/BuildSystem/retrieval.py:261: Unused function 'bkfileRetrieve' config/BuildSystem/retrieval.py:266: Unused function 'sshRetrieve' config/BuildSystem/retrieval.py:271: Unused function 'oldRetrieve' config/BuildSystem/script.py:41: Unused attribute 'shell' config/BuildSystem/script.py:83: Unused attribute '_setup' config/BuildSystem/script.py:293: Unused attribute 'outputFiles' config/BuildSystem/script.py:414: Unused function 'setPreprocessorObject' config/BuildSystem/script.py:428: Unused function 'setCompilerObject' config/BuildSystem/script.py:444: Unused function 'setLinkerObject' config/BuildSystem/script.py:476: Unused function 'setDynamicLinkerObject' config/BuildSystem/sourceDatabase.py:185: Unused function 'clearSource' config/BuildSystem/sourceDatabase.py:194: Unused function 'getDependencies' config/BuildSystem/sourceDatabase.py:215: Unused function 'calculateDependencies' config/BuildSystem/sourceDatabase.py:281: Unused class 'DependencyAnalyzer' config/BuildSystem/urlMappingInstalled.py:14: Unused function 'setupUrlMapping' config/cmakeboot.py:22: Unused function 'quoteIfNeeded' config/cmakegen.py:64: Unused function 'unexpected' config/examples/arch-bgp-ibm-opt.py:63: Unused variable 'test_options' config/PETSc/Configure.py:58: Unused attribute 'atomics' config/PETSc/Configure.py:739: Unused variable 'langs' config/PETSc/FEM.py:877: Unused function 'createFaceQuadrature' config/PETSc/FEM.py:904: Unused attribute 'list' config/PETSc/FEM.py:907: Unused attribute 'type' config/PETSc/FEM.py:909: Unused attribute 'static' config/PETSc/FEM.py:910: Unused attribute 'initializer' config/PETSc/FEM.py:923: Unused attribute 'identifier' config/PETSc/FEM.py:924: Unused attribute 'replacementText' config/PETSc/FEM.py:1098: Unused function 'getReferenceTensor' config/PETSc/FEM.py:1357: Unused attribute 'typedef' config/PETSc/FEM.py:1386: Unused function 'getQuadratureSetup' config/PETSc/FEM.py:1394: Unused attribute 'branch' config/PETSc/FEM.py:1449: Unused function 'getIntegratorPoints' config/PETSc/FEM.py:1510: Unused attribute 'caseLabel' config/PETSc/FEM.py:1569: Unused function 'getIntegratorSetup' config/PETSc/FEM.py:1578: Unused function 'getSectionSetup' config/PETSc/FEM.py:1669: Unused function 'getElementIntegrals' config/PETSc/FEM.py:1696: Unused attribute 'parameters' config/PETSc/FEM.py:1758: Unused attribute 'comments' config/PETSc/FEM.py:1814: Unused attribute 'purpose' config/PETSc/FEM.py:1904: Unused function 'runTensorProduct' config/PETSc/utilities/arch.py:54: Unused attribute 'archBase' config/PETSc/utilities/cacheDetails.py:29: Unused attribute 'updated' config/PETSc/utilities/CHUD.py:39: Unused attribute 'haveCHUD' config/PETSc/utilities/libraryOptions.py:33: Unused attribute 'scalarTypes' config/PETSc/utilities/missing.py:86: Unused function 'configureMissingErrnos' config/PETSc/utilities/Regression.py:27: Unused attribute ‘elemental'
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Barry Smith
