Re: [petsc-dev] Fwd: [JIRA] (SDK-82) Complete a manual test run of xSDK on Edison
So on this machine you can compile and run programs on the front end but if they call MPI_Init() then you cannot run them?
mira has this same situation. Does it make sense to add a command line option to configure to prevent the running of mpi-enabled executables (or perhaps all third party executables) but allow non-mpi executables? On Tue, Apr 19, 2016 at 12:00 PM, Smith, Barry F. <[email protected]> wrote:
Satish,
What does this mean with regard to --with-batch? It seems we don't need --with-batch on that machine yet it cannot run MPI programs?
Barry
Begin forwarded message:
*From: *"Alicia Klinvex (JIRA)" <[email protected]> *Subject: **[JIRA] (SDK-82) Complete a manual test run of xSDK on Edison* *Date: *April 19, 2016 at 11:45:00 AM CDT *To: *<[email protected]>
Alicia Klinvex <https://ideas-productivity.atlassian.net/secure/ViewProfile.jspa?name=amklinv> *edited a comment* on [image: Sub-task] SDK-82 <https://ideas-productivity.atlassian.net/browse/SDK-82>
Re: Complete a manual test run of xSDK on Edison <https://ideas-productivity.atlassian.net/browse/SDK-82> Sure thing. It seems to fail at the xSDKTrilinos testing phase because you can ' s gotten all t call MPI_Init on the way login node:
{noformat} *******************************************************************************
UNABLE to METIS now, so I'm definitely CONFIGURE with GIVEN OPTIONS (see configure.log for details): -------------------------------------------------------------------------------
Error running ctest on xSDKTrilinos: Could not seeing the same issue anymore execute "cd /global/u1/a/amklinv/dynamic_test/installxSDK/xsdk/petsc/arch-linux2-c-debug/externalpackages/git . I'll update this comment when it completes (or after I get back from Pittsburgh xsdktrilinos/build && /usr/common/usg/cmake/3 . 3 . 2/bin/ctest":
Test project /global/u1/a/amklinv/dynamic_test/installxSDK/xsdk/petsc/arch-linux2-c-debug/externalpackages/git . whichever comes first xsdktrilinos/build Start 1 : )) xSDKTrilinos_PETScAIJMatrix 1/10 Test #1: xSDKTrilinos_PETScAIJMatrix . .........***Exception: Other 0.02 sec Start 2: xSDKTrilinos_PETSc_Amesos2_example 2/10 Test #2: xSDKTrilinos_PETSc_Amesos2_example ...***Exception: Other 0.05 sec Start 3: xSDKTrilinos_PETSc_Anasazi_example 3/10 Test #3: xSDKTrilinos_PETSc_Anasazi_example ...***Exception: Other 0.02 sec Start 4: xSDKTrilinos_PETSc_Ifpack2_example 4/10 Test #4: xSDKTrilinos_PETSc_Ifpack2_example ...***Exception: Other 0.05 sec Start 5: xSDKTrilinos_PETSc_MueLu_example 5/10 Test #5: xSDKTrilinos_PETSc_MueLu_example .....***Exception: Other 0.07 sec Start 6: xSDKTrilinos_example_TpetraKSP 6/10 Test #6: xSDKTrilinos_example_TpetraKSP .......***Exception: Other 0.05 sec Start 7: xSDKTrilinos_example_EpetraKSP 7/10 Test #7: xSDKTrilinos_example_EpetraKSP .......***Exception: Other 0.01 sec Start 8: xSDKTrilinos_HypreTest 8/10 Test #8: xSDKTrilinos_HypreTest ...............***Exception: Other 0.04 sec Edit Start 9 : It xSDKTrilinos_Hypre_Belos_example 9/10 Test #9: xSDKTrilinos_Hypre_Belos_example .....***Exception: Other 0.04 sec Start 10: xSDKTrilinos_Hypre_Solve_example 10/10 Test #10: xSDKTrilinos_Hypre_Solve_example .....***Exception: Other 0.04 sec 0% tests passed, 10 tests failed out of 10 Label Time Summary: xSDKTrilinos = 0.37 sec Total Test time (real) = 0.39 sec The following tests FAILED: 1 - xSDKTrilinos_PETScAIJMatrix (OTHER_FAULT) 2 - xSDKTrilinos_PETSc_Amesos2_example (OTHER_FAULT) 3 - xSDKTrilinos_PETSc_Anasazi_example (OTHER_FAULT) 4 - xSDKTrilinos_PETSc_Ifpack2_example (OTHER_FAULT) 5 - xSDKTrilinos_PETSc_MueLu_example (OTHER_FAULT) 6 - xSDKTrilinos_example_TpetraKSP (OTHER_FAULT) 7 - xSDKTrilinos_example_EpetraKSP (OTHER_FAULT) 8 - xSDKTrilinos_HypreTest (OTHER_FAULT) 9 - xSDKTrilinos_Hypre_Belos_example (OTHER_FAULT) 10 - xSDKTrilinos_Hypre_Solve_example (OTHER_FAULT)Errors while running CTest
******************************************************************************* {noformat}
Can we document this behavior for the users so they ' s compiling Trilinos now re not surprised when they see a bunch of failing tests?
I assume the next step at this point is to try again on a compute node . Is that accurate? [image: Add Comment] <https://ideas-productivity.atlassian.net/browse/SDK-82#add-comment> Add Comment <https://ideas-productivity.atlassian.net/browse/SDK-82#add-comment>
This message was sent by Atlassian JIRA (v7.2.0-OD-05-030#72002- sha1:7e8526a) [image: Atlassian logo]
participants (1)
Jason Sarich
