Re: [petsc-dev] slow "ar Scq" on cygwin
$ PETSC_DIR=/cygdrive/d/petsc-dev-2012-06-26 PETSC_ARCH=test_8 ./config/builder.py (The same happens (existing .o are deleted) if ./config/builder2.py build is used)
This is not what I wrote. You used builder.py, which is python 2.4 compatible, but has to do everything without options, so yes it deletes all the objects and rebuilds everything. That is why I did not suggest you use it.
I said to use builder2.py, which does proper dependency tracking.
That is what I used and I mentioned it above. I've tried both separately. Both give the same result that libpetsc.lib is not created. And whether I use builder.py or builder2.py, the existing objects files are deleted in the second build. I did not call for a cleanup. To be sure, I tried the whole thing in a new ARCH with a fresh configure step, and this time builder.py was not used at all (by me) but it led to the same issues with builder2.py. I understand that this is not the most used platform, so let me know if I can be of help. And I forgot to mention that the python build was 4-5 times faster than "ar" based build and that's great... Chetan From: [email protected] [mailto:[email protected]] On Behalf Of Matthew Knepley Sent: Thursday, June 28, 2012 3:21 PM To: For users of the development version of PETSc Subject: Re: [petsc-dev] slow "ar Scq" on cygwin On Thu, Jun 28, 2012 at 4:10 PM, Chetan Jhurani <[email protected]> wrote: Matt, I was surprised too on both counts. Couldn't find any libpetsc.lib after the python build and I did not run "clean" in between that could have deleted the .o files. Here's one more try below to show it. $ ls test_8/lib/ libpetsc-obj $ ls test_8/lib/libpetsc-obj/ | wc -l 560 $ PETSC_DIR=/cygdrive/d/petsc-dev-2012-06-26 PETSC_ARCH=test_8 ./config/builder.py (The same happens (existing .o are deleted) if ./config/builder2.py build is used) This is not what I wrote. You used builder.py, which is python 2.4 compatible, but has to do everything without options, so yes it deletes all the objects and rebuilds everything. That is why I did not suggest you use it. I said to use builder2.py, which does proper dependency tracking. Matt Rebuilding Dependencies Building in /cygdrive/d/petsc-dev-2012-06-26/src/sys Building in /cygdrive/d/petsc-dev-2012-06-26/src/sys/bag Building in /cygdrive/d/petsc-dev-2012-06-26/src/sys/comm Building in /cygdrive/d/petsc-dev-2012-06-26/src/sys/dll I stopped the build using control-c. It would have deleted all files first. Traceback (most recent call last): File "./config/builder.py", line 1534, in <module> PETScMaker().run() File "./config/builder.py", line 1526, in run if self.buildLibraries('libpetsc', self.rootDir): File "./config/builder.py", line 1331, in buildLibraries objects += self.buildDir(root, files, objDir) File "./config/builder.py", line 1251, in buildDir objects.extend(getattr(self, 'compile'+language)(sourceMap[language], objDir)) File "./config/builder.py", line 1025, in compileC return self.compile(self.configInfo.languages.clanguage, source, objDir) File "./config/builder.py", line 1012, in compile (output, error, status) = self.executeShellCommand(cmd, checkCommand = noCheckCommand, log=self.log) File "/cygdrive/d/petsc-dev-2012-06-26/config/BuildSystem/script.py", line 254, in executeShellCommand (output, error, status) = runInShell(command, log, cwd) File "/cygdrive/d/petsc-dev-2012-06-26/config/BuildSystem/script.py", line 243, in runInShell thread.join(timeout) File "/usr/lib/python2.6/threading.py", line 655, in join self.__block.wait(delay) File "/usr/lib/python2.6/threading.py", line 258, in wait _sleep(delay) KeyboardInterrupt $ ls test_8/lib/libpetsc-obj/ bag.o All the previous .o were deleted. Perhaps I'm not doing something right? Chetan From: [email protected] [mailto:[email protected]] On Behalf Of Matthew Knepley Sent: Thursday, June 28, 2012 2:46 PM To: For users of the development version of PETSc Subject: Re: [petsc-dev] slow "ar Scq" on cygwin On Thu, Jun 28, 2012 at 3:31 PM, Chetan Jhurani <[email protected]> wrote: Thanks Matt, Satish. A few issues though. Like you said, the latest cygwin has python 2.6.8 which does not have argparse. When I place the following in path http://argparse.googlecode.com/svn/trunk/argparse.py I can run the python build with 2.6.8. However, the "ar" based build had worked fine and the python based build fails for these two files. src/snes/impls/MULTIB~1/multiblock.c src/snes/impls/vi/rsaug/virsaug.c Yep, it fails, but the build succeeds, so no problem. It looks like these two files were NOT compiled in the ar based build. The two make.log files are attached. One more question. I tried to run the python based build the second time (after it was unsuccessful the first time) and then it deleted all the previous .o files it had created in ARCH/lib/libpetsc-obj. How can that be avoided? It does not do that unless you run 'clean'. Matt Chetan From: [email protected] [mailto:[email protected]] On Behalf Of Matthew Knepley Sent: Thursday, June 28, 2012 1:35 PM To: For users of the development version of PETSc Subject: Re: [petsc-dev] slow "ar Scq" on cygwin On Thu, Jun 28, 2012 at 2:23 PM, Chetan Jhurani <[email protected]> wrote: Hi devs, Is there a way to avoid running the archiver (ar) every time a petsc directory is compiled? The reason I'm asking this is that when libpetsc.lib becomes large enough (say 100MB+, esp. for debug build), "ar Sqc" on cygwin takes very long in each directory. Depending on OS caching, very long can be 10 seconds per PETSc directory just to run ar. It creates a new temp file from scratch, puts stuff from libpetsc.lib and new stuff in it and then renames the temp file. As you can imagine, the compilation process is fast in the beginning but crawls by the end. I've seen the same IO sequence on Linux (with Sqc flags to ar), but since cygwin IO is slower the effect is more clearly visible. Building within a ramdisk leads to 25% faster compilation but it was more of a curiosity. Build with Python. It never uses antique things like ar :) python2.7 ./config/builder2.py build Matt Chetan -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener -- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Chetan Jhurani
