Fixed. Matt On Mon, Jul 21, 2008 at 3:32 PM, Barry Smith <[email protected]> wrote:
Matt,
While you are at it could you please fix the buggy code in mprint.c?
make PETSC_DIR=/Users/bsmith/Src/petsc-dev-for-fixes PETSC_ARCH=arch-icc-ifort /Users/bsmith/Src/petsc-dev-for-fixes/arch-icc-ifort/bin/mpicc -o mprint.o -c -wd1572 -Qoption,cpp,--extended_float_type -g -I/Users/bsmith/Src/petsc-dev-for-fixes -I/Users/bsmith/Src/petsc-dev-for-fixes/arch-icc-ifort/include -I/Users/bsmith/Src/petsc-dev-for-fixes/include -I/usr/X11/include -I/Users/bsmith/Src/petsc-dev-for-fixes/arch-icc-ifort/include -D__SDIR__='"src/sys/fileio/"' mprint.c mprint.c(350): warning #592: variable "fullLength" is used before its value is set while(fullLength >= next->size) { ^
On Jul 21, 2008, at 3:30 PM, Matthew Knepley wrote:
Pushed a fix. I missed the Viewer when I corrected the raw call. That should not be separate code.
Matt
On Mon, Jul 21, 2008 at 2:54 PM, Satish Balay <[email protected]> wrote:
Matt - Perhaps ex7 is a different Problem. But it does crash for me. And I noticed the following code:
ierr = PetscNew(struct _PrintfQueue,&next);CHKERRQ(ierr); if (queue) {queue->next = next; queue = next;} else {queuebase = queue = next;} queuelength++; string = next->string; ierr = PetscMemzero(string,QUEUESTRINGSIZE);CHKERRQ(ierr); <<<<<<<<<
i.e 'next' is allocated - here is no malloc for 'next->string'. But its being zeroed in PetscMemzero() - hence the crash with ex7 for me.
Satish
asterix:/home/balay/spetsc/src/dm/ao/examples/tests>mpiexec -n 2 ./ex7 Number of elements in ordering 10 PETSc->App App->PETSc 0 0 0 0 1 5 1 2 2 1 2 4 3 6 3 6 4 2 4 8 5 7 5 1 6 3 6 3 7 8 7 5 8 4 8 7 9 9 9 9 [1]PETSC ERROR: --------------------- Error Message ------------------------------------ [1]PETSC ERROR: Null argument, when expecting valid pointer! [1]PETSC ERROR: Trying to zero at a null pointer! [1]PETSC ERROR: ------------------------------------------------------------------------ [1]PETSC ERROR: Petsc Development Version 2.3.3, Patch 13, unknown HG revision: unknown [1]PETSC ERROR: See docs/changes/index.html for recent updates. [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting. [1]PETSC ERROR: See docs/index.html for manual pages. [1]PETSC ERROR: ------------------------------------------------------------------------ [1]PETSC ERROR: ./ex7 on a asterix64 named asterix by balay Mon Jul 21 14:51:02 2008 [1]PETSC ERROR: Libraries linked from /home/balay/spetsc/lib [1]PETSC ERROR: Configure run at Mon Jul 21 10:38:52 2008 [1]PETSC ERROR: Configure options --with-mpi-dir=/home/balay/soft/linux64/mpich2-1.0.7 --with-shared=1 PETSC_ARCH=asterix64 [1]PETSC ERROR: ----------------------------[0] Number of indices in (stride) set 5 [0] 0 0 [0] 1 2 [0] 2 4 [0] 3 6 [0] 4 8 -------------------------------------------- [1]PETSC ERROR: PetscMemzero() line 189 in src/sys/utils/memc.c [1]PETSC ERROR: PetscViewerASCIISynchronizedPrintf() line 859 in src/sys/viewer/impls/ascii/filev.c [1]PETSC ERROR: ISView_Stride() line 231 in src/vec/is/impls/stride/stride.c [1]PETSC ERROR: ISView() line 398 in src/vec/is/interface/index.c [1]PETSC ERROR: main() line 31 in src/dm/ao/examples/tests/ex7.c application called MPI_Abort(MPI_COMM_WORLD, 85) - process 1[cli_1]: aborting job: application called MPI_Abort(MPI_COMM_WORLD, 85) - process 1 [0]0:Return code = 0, signaled with Interrupt [0]1:Return code = 85 asterix:/home/balay/spetsc/src/dm/ao/examples/tests>
On Mon, 21 Jul 2008, Matthew Knepley wrote:
I made this change because synchronized printing was cutting off my stuff. Now the queue is dynamically allocated so it can accomodate any size string.
I tried ex7 and it runs fine for me, even under valgrind.
Shi, can you reproduce this with a Sieve example?
Matt
On Mon, Jul 21, 2008 at 2:37 PM, Satish Balay <[email protected]> wrote:
Looks like this could be related to changeset 9e3fbe04a926
--> mprint.h <--
- char string[QUEUESTRINGSIZE]; + char *string;
So now strings needs to use malloc()/free()?
Matt - you can reproduce this issue with dm/ao/examples/tests/ex7.c
Satish
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Matthew Knepley
