Re: [petsc-dev] mpi.mod --with-fortran-interfaces=0
For now, I’ve merely removed the runtime error from there https://gitlab.com/petsc/petsc/-/commit/68bd534a466d12bdec28b4c298b715271ec2... <https://gitlab.com/petsc/petsc/-/commit/68bd534a466d12bdec28b4c298b715271ec2dd31#379d0ed64a11c2a30793be16c20a756695f74407_515_513> And configure seems to be happy (for now… my Windows VM is way to slow…) http://joliv.et/configure_msmpi.log <http://joliv.et/configure_msmpi.log> I will try your diff as well (in about one hour and a half when the first build is through). Thanks, Pierre
On 24 Mar 2021, at 3:10 PM, Satish Balay <[email protected]> wrote:
On Wed, 24 Mar 2021, Pierre Jolivet wrote:
On 24 Mar 2021, at 2:55 PM, Matthew Knepley <[email protected]> wrote:
On Wed, Mar 24, 2021 at 9:37 AM Pierre Jolivet <[email protected] <mailto:[email protected]>> wrote: Hello, It seems mpi.mod is now mandatory https://gitlab.com/petsc/petsc/-/commit/68bd534a466d12bdec28b4c298b715271ec2... <https://gitlab.com/petsc/petsc/-/commit/68bd534a466d12bdec28b4c298b715271ec2dd31>. mpi.mod is not shipped by MS-MPI. I want to build MUMPS through PETSc and don’t really care about the Fortran PETSc interface on our Windows boxes (--with-fortran-interfaces=0).
I think you want --with-fc=0, which should turn off this check.
No, I have gfortran, I want to compile MUMPS with PETSc, that won’t work --with-fc=0. Also, the error message in the configure is wrong, it should read "PETSc Fortran bindings” (not “fortran interface”), and in my email, one should replace --with-fortran-interfaces by --with-fortran-bindings, sorry about that. I guess there is a missing check before raise RuntimeError('mpi.mod not found! PETSc fortran interface requires a working mpi.mod'), like if self.argDB['with-fortran-interfaces'] But I don’t know if that makes sense.
I guess you mean:
diff --git a/config/BuildSystem/config/packages/MPI.py b/config/BuildSystem/config/packages/MPI.py index 7ea2716cc5..5a1baff9f9 100644 --- a/config/BuildSystem/config/packages/MPI.py +++ b/config/BuildSystem/config/packages/MPI.py @@ -497,7 +497,7 @@ Unable to run hostname to check the network')
def FortranMPICheck(self): '''Make sure fortran include [mpif.h] and library symbols are found''' - if not hasattr(self.compilers, 'FC'): + if not hasattr(self.compilers, 'FC') or not self.argDB['with-fortran-bindings']: return 0 # Fortran compiler is being used - so make sure mpif.h exists self.libraries.pushLanguage('FC')
If MS-MPI is missing mpi.mod - I guess we'll have to revert this requirement. For some reason the tests in CI don't error out. I'll have to check.
I can add back mpif.h usage [without the extra complex code we had for handling some corner cases - in this mode]
Satish
Thanks, Pierre
Matt
Yet, I’m now hit by: ******************************************************************************* UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for details): ------------------------------------------------------------------------------- mpi.mod not found! PETSc fortran interface requires a working mpi.mod ******************************************************************************* Could this be fixed somehow, please? Thanks, Pierre
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Pierre Jolivet
