Re: [petsc-dev] [petsc-users] Loading Binary file problem
It would be nice if the error message could be related to the VecLoad() call so the error message could say that there is no vector next in the file.
[d3m956@olympus tutorials]$ ./ex12 -f0 myA.dat
This program expects a matrix followed by a vector in the file. You can use -rhs 0 to skip reading the right hand side vector from the file, it will use a vector of all ones.
[0]PETSC ERROR: --------------------- Error Message ------------------------------------ [0]PETSC ERROR: Read from file failed! [0]PETSC ERROR: Read past end of file! [0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: Petsc Release Version 3.3.0, Patch 0, Tue Jun 5 14:20:42 CDT 2012 [0]PETSC ERROR: See docs/changes/index.html for recent updates. [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting. [0]PETSC ERROR: See docs/index.html for manual pages. [0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: ./ex12 on a arch-linu named olympus.local by d3m956 Tue Jun 26 13:51:28 2012 [0]PETSC ERROR: Libraries linked from /pic/projects/mca/ss/PETSC/petsc-3.3-p0/arch-linux2-c-debug/lib [0]PETSC ERROR: Configure run at Thu Jun 14 17:00:19 2012 [0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran --download-f-blas-lapack --download-mpich [0]PETSC ERROR: ------------------------------------------------------------------------ [0]PETSC ERROR: PetscBinaryRead() line 271 in src/sys/fileio/sysio.c [0]PETSC ERROR: PetscBinarySynchronizedRead() line 558 in src/sys/fileio/sysio.c [0]PETSC ERROR: PetscViewerBinaryRead() line 764 in src/sys/viewer/impls/binary/binv.c [0]PETSC ERROR: PetscViewerBinaryReadVecHeader_Private() line 24 in src/vec/vec/utils/vecio.c [0]PETSC ERROR: VecLoad_Binary() line 97 in src/vec/vec/utils/vecio.c [0]PETSC ERROR: VecLoad_Default() line 348 in src/vec/vec/utils/vecio.c [0]PETSC ERROR: VecLoad() line 1111 in src/vec/vec/interface/vector.c [0]PETSC ERROR: main() line 92 in src/mat/examples/tutorials/ex12.c
It said “Read from file failed! Read past end of file!” Anything wrong? I was using the example code without changing anything. Please help me to figure out the problem.
Thanks, Shuangshuang
participants (1)
Barry Smith
