Re: [petsc-dev] PETSc Sorting with duplicate entries
31 Mar
31 Mar
'11
11:34 a.m.
PetscSortIntWithPermutation() implements bubble sort for n<8 and insertion sort otherwise, which does not give ordered index for duplicate entries. If you can find the algorithm used by Matlab, please let us know. We can implement it. Otherwise, I think you may write a subroutine to sort index() of duplicate entries, which takes O(n) operations, a low order operation comparing to sort().
Why can't the sort routine simply use two comparisons? In particular, you use the value as the first comparison and in case of ties use the index to break ties? This means that there are no identical values assuming all indices are unique. Cheers, Todd.
5612
Age (days ago)
5612
Last active (days ago)
0 comments
1 participants
participants (1)
Todd Munson
