Re: [petsc-dev] new configuration/compile system for PETSc
On Sat, Jul 9, 2011 at 7:18 PM, Harald Pfeiffer <[email protected]> wrote:
We happen to use Petsc with our own makefiles. PETSc is compiled entirely separately (or we use system-provided PETSc-modules). We then manually set the appropriate include- and library-paths in our makefiles, for example:
PETSC_INCLUDE = -I$(PETSC_DIR)/include -I$(PETSC_DIR)/$(PETSC_ARCH)/include PETSC_LIB = -L$(PETSC_DIR)/$(PETSC_ARCH)/lib -lpetsc -lX11 ... other stuff here ... ARCH_INCLUDE = $(PETSC_INCLUDE) ... ARCH_LIB_PARALLEL = $(HDF_LIB) $(FFTW_LIB) $(PETSC_LIB) ....
Not elegant, but has been working like a charm for the last 12 years.
I'm not saying it can't be made to work. I'm saying it might not be trivial for someone just starting to use PETSc and not even necessarily that familiar with make: there are a lot of potential users like that. And even for more sophisticated users it might take a while to work out the kinks. Dmitry.
Harald
On 7/10/11 1:02 AM, Dmitry Karpeev wrote:
On Sat, Jul 9, 2011 at 6:42 PM, Jed Brown<[email protected]> wrote:
On Sat, Jul 9, 2011 at 18:30, Dmitry Karpeev<[email protected]> wrote:
If a user could write a simple foo.py that configured/built their favorite package with PETSc as a dependency, they could then proceed to modify the FOO code and jack PETSc into it.
But this just a different form of asking them to adopt our build system, except that makefiles are a de-facto standard and our system won't be familiar to anyone. Any system has to be easily usable from other systems (at least makefiles, automake, and cmake).
Yes, but there is also a practical problem: an engineer or a scientist, not intimately familiar with automake, cmake, etc., has taken the effort to understand PETSc so that our linear solvers can be substituted for FOO's. How can we make it easier for these people to insert PETSc into their code? Here I only mean the build process. Maybe making them write foo.py is not the right approach, but we should have a usable approach (and, maybe, an example of doing it).
In particular, is it sufficient to export linklibs, or do we also need to export the compiler (e.g., to ensure consistent Fortrant name mangling)? There are a good number of Fortran users that want to use PETSc too.
Dmitry.
-- Harald Pfeiffer Assistant Professor Cdn. Institute for Theoretical Astrophysics University of Toronto [email protected] Tel. ++1 416-978-8497
participants (1)
Dmitry Karpeev
