Re: [petsc-dev] [petsc-maint #80119] Re: make install broken on unix?
On 30 July 2011 16:18, Jed Brown <[email protected]> wrote:
Does that mean we can just add python utilities to that package, or do we need to create petsc-util?
Currently, if you "pip install petsc", pip will download PETSc's tarball release (the -lite one), configure, build and install (in Python's site-package directory). Most of the installed stuff are header and libraries, and no Python code. Remember this is just a hack after Barry's loud insistence to get petsc4py easy-installable, even if the user do not have a previous PETSc install. So they get what they deserve... So, I think this package is not appropriate for adding utilities. I think your only option is to set a lawsuit on me for using the "petsc" name for my own purpose :-) After we are somehow in software business, right?. After being asked to pay millions of dollars, I will eventually give up and start using "libpetsc" for what petsc4py needs as a dependency...
On Jul 30, 2011 12:07 PM, "Lisandro Dalcin" <[email protected]> wrote:
On 25 July 2011 19:33, Jed Brown <[email protected]> wrote:
On Mon, Jul 25, 2011 at 10:16, Ethan Coon <[email protected]> wrote:
It's not really a stand-alone script though, so it shouldn't get the hashbang or lose the extension. But it's not a full-fledged package of libraries either. I don't think it should be anywhere in the default path -- it's the kind of code that you should have to explicitly include (either via sys.path manipulation or via PYTHONPATH) because too many little scripts of utility code makes for a nasty, polluted namespace. There just isn't a good place (that I know of) in the standard file system hierarchy for this kind of stuff.
Making the user/scripts do manual sys.path or PYTHONPATH manipulation makes it nearly impossible to make portable scripts that depend on these functions. Should we start a "proper" Python package containing PETSc utilities? Then scripts could rely on from petsc.io import binary_read or whatever working. Of course it might only contain two functions right now, but I could add my "petscplot" (makes various types of convergence and scaling plots from convergence monitors and -log_summary output), and I'm sure the community has other useful scripts.
Note however that "petsc" package is already registered in PyPI to make "pip install petsc4py" download and install PETSc.
-- Lisandro Dalcin --------------- CIMEC (INTEC/CONICET-UNL) Predio CONICET-Santa Fe Colectora RN 168 Km 472, Paraje El Pozo 3000 Santa Fe, Argentina Tel: +54-342-4511594 (ext 1011) Tel/Fax: +54-342-4511169
participants (1)
Lisandro Dalcin
