Re: [petsc-dev] why am I getting this message?
On Wed, 27 Sep 2017, Mark Adams wrote:
On Wed, Sep 27, 2017 at 9:00 AM, Satish Balay <[email protected]> wrote:
What url do you have for origin? Send output from:
git config --local -l
07:53 cori01 maint= ~/petsc_install/petsc$ git config --local -l core.repositoryformatversion=0 core.filemode=true core.bare=false core.logallrefupdates=true remote.origin.url=https://[email protected]/petsc/petsc.git remote.origin.fetch=+refs/heads/*:refs/remotes/origin/* branch.master.remote=origin branch.master.merge=refs/heads/master branch.mark/snes-ex56c.remote=origin branch.mark/snes-ex56c.merge=refs/heads/mark/snes-ex56c branch.maint.remote=origin branch.maint.merge=refs/heads/maint branch.hzhang/fix-nonscalable-ctable-use.remote=origin branch.hzhang/fix-nonscalable-ctable-use.merge=refs/heads/hzhang/fix-nonscalable-ctable-use 07:53 cori01 maint= ~/petsc_install/petsc$
And do you have to list 'origin' in pull? [I guess you need to do that if you have multiple remotes?]
I don't have multiple remotes
And what do you have for:
git fetch origin git describe origin/maint git describe maint
07:54 cori01 maint= ~/petsc_install/petsc$ git fetch origin 07:55 cori01 maint= ~/petsc_install/petsc$ git describe origin/maint v3.8 07:55 cori01 maint= ~/petsc_install/petsc$ git describe origin/maint
This should be 'git describe maint' Satish
Satish
I just pulled maint but still get a message that I am out of date:
1072 git pull origin 1073 h 05:12 cori01 maint= ~/petsc_install/petsc$ ../arch-cori-knl-opt-intel.py PETSC_DIR=$PWD ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++++++++++++++++++++++++++ The version of PETSc you are using is out-of-date, we recommend updating to the new release Available Version: 3.8 Installed Version: 3.7.6 http://www.mcs.anl.gov/petsc/download/index.html ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ +++++++++++++++++++++++++++++++ ============================================================ =================== Configuring PETSc to compile on your system
participants (1)
Satish Balay
