Re: [petsc-dev] Generality of VecScatter
On Thu, Nov 24, 2011 at 16:01, Barry Smith <[email protected]> wrote:
Yes, but they can only get access to that shared variable one at a time: first get's it, then second get's it, then third gets, .... Ok for a couple of cores but not for dozens.
Take a look at src/sys/objects/pthread.c for the various ways we have coded for "waking" the threads. Maybe I am missing something but this is the best Kerry and I could figure out.
What exactly should I be looking at? Can't you have all the threads spin on a normal shared variable (not a mutex) that is only written by the thread that needs to spark them? Or use a fetch-and-add atomic if you want to keep track of how many are running or limit the number? The latter could use a tree to get logarithmic cost, but if they are stored next to each other, you would still have O(P) cache invalidations.
participants (1)
Jed Brown
