Re: [petsc-dev] Issues with DMComplexGetTransitiveClosure in Fortran
Oh ok that makes sense. The nomenclature was confusing me. On Thu, Aug 30, 2012 at 10:53 AM, Matthew Knepley <[email protected]> wrote:
On Thu, Aug 30, 2012 at 11:49 AM, Chris Eldred <[email protected]> wrote:
That is what I have already been doing- so that is good! As far as the ordering convention goes, for a 2D mesh I should have vertices, faces (what I have been calling cells) and then edges? Ex. for the doublet mesh it would be 0,1,2,3 (vertices); 4,5 (faces); 6,7,8,9,10 (edges)?
No, I do it exactly as in ex2f90:
cells: 0,1 vertices: 2,3,4,5 edges: 6,7,8,9,10
Nomenclature:
vertex: Complex in mesh of dimension 0 cell: Complex in mesh of co-dimension 0 (so highest dimension possible) edge: Complex of dimension 1 face: Complex of co-dimension 1 (notice it can also be an edge in 2D)
Matt
On Wed, Aug 29, 2012 at 8:51 PM, Matthew Knepley <[email protected]> wrote:
On Wed, Aug 29, 2012 at 1:35 PM, Chris Eldred <[email protected]> wrote:
DMComplexGetTransitiveClosure (and Restore) work fine now. What are the new restrictions on numbering mentioned in src/dm/impls/complex/examples/tests/ex2f90.F?
In the original Sieve, you could use any id for any point. This is very flexible, but hugely expensive in terms of memory, and somewhat expensive in terms of time.
In DMComplex, each stratum in the DAG (it is technically a ranked poset) must be numbered contiguously. This means that vertices, faces, etc. are all numbered contiguously. It turns out that in practice, this is not an onerous requirement, and it allows very effective optimizations.
In addition, we have the convention that we number cells, then vertices, then faces, then edges. Nothing in the interface demands it, but all of the PETSc code for FEM obeys this since it simplifies debugging.
Matt
On Tue, Aug 28, 2012 at 8:16 PM, Matthew Knepley <[email protected]> wrote:
On Tue, Aug 28, 2012 at 5:01 PM, Chris Eldred <[email protected]> wrote:
On Tue, Aug 28, 2012 at 3:49 PM, Matthew Knepley <[email protected]> wrote:
On Tue, Aug 28, 2012 at 4:39 PM, Chris Eldred <[email protected]> wrote:
DMComplexGetTransitiveClosure does not appear to have the calling sequence (DM dm, PetscInt p, PetscBool useCone, PetscInt *numPoints, PetscInt *points[]) indicated in the documentation- instead it has DM dm, PetscInt p, PetscBool useCone, PetscInt *points[]. In addition, it does not appear to be returning the full closure- instead it just gives cone + the point.
1) I will turn this code into a running example
Awesome! I have been using the Doublet mesh to test DMComplex routines and my own functions, so that is great.
Okay, there was a bug in the array handling. The test is
Matt
2) I will fix the documentation. The interface change for Fortran comes because the size is embedded in the array pointer. If you think I should still return the size in Fortran, let me know.
I can get the size from the array pointer so just returning that works.
3) I will also check to make sure the documentation is clear that this thing returns each point AND its orientation.
Will write again when I have your thing running. It could be an error with the Fortran array processing I put in.
Matt
Sample code is below:
program main implicit none ! ! #echo '#include <finclude/petscsys.h>\n' #echo '#include <finclude/petsc.h90>' #echo '#include <finclude/petscdmcomplex.h>\n' #echo '#include <finclude/petscdmcomplex.h90>' ! #echo '#include <finclude/petscdm.h>\n' ! #echo '#include <finclude/petscdm.h90>\n'
! DM dm PetscInt, target, dimension(3) :: EC PetscInt, target, dimension(2) :: VE PetscInt, pointer :: pEC(:), pVE(:) PetscInt, pointer :: nClosure(:) PetscInt, pointer :: pClosure(:), pCone(:), pCone2(:) PetscErrorCode ierr
call PetscInitialize(PETSC_NULL_CHARACTER,ierr) CHKERRQ(ierr) call DMComplexCreate(PETSC_COMM_WORLD, dm, ierr) CHKERRQ(ierr)
!Make Doublet Mesh from Fig 2 of Flexible Representation of Computational Meshes (except indexing is from 0 instead of 1) call DMComplexSetChart(dm, 0, 11, ierr) CHKERRQ(ierr)
call DMComplexSetConeSize(dm, 9, 3,ierr) CHKERRQ(ierr) call DMComplexSetConeSize(dm, 10, 3,ierr) CHKERRQ(ierr) call DMComplexSetConeSize(dm, 4, 2,ierr) CHKERRQ(ierr) call DMComplexSetConeSize(dm, 5, 2,ierr) CHKERRQ(ierr) call DMComplexSetConeSize(dm, 6, 2,ierr) CHKERRQ(ierr) call DMComplexSetConeSize(dm, 7, 2,ierr) CHKERRQ(ierr) call DMComplexSetConeSize(dm, 8, 2,ierr) CHKERRQ(ierr)
call DMSetUp(dm, ierr) CHKERRQ(ierr)
EC(1) = 4 EC(2) = 5 EC(3) = 6 pEC => EC call DMComplexSetCone(dm, 9 , pEC, ierr) CHKERRQ(ierr) EC(1) = 6 EC(2) = 7 EC(3) = 8 pEC => EC call DMComplexSetCone(dm, 10 , pEC, ierr) CHKERRQ(ierr)
VE(1) = 0 VE(2) = 1 pVE => VE call DMComplexSetCone(dm, 4 , pVE, ierr) CHKERRQ(ierr) VE(1) = 0 VE(2) = 2 pVE => VE call DMComplexSetCone(dm, 5 , pVE, ierr) CHKERRQ(ierr) VE(1) = 1 VE(2) = 2 pVE => VE call DMComplexSetCone(dm, 6 , pVE, ierr) CHKERRQ(ierr) VE(1) = 2 VE(2) = 3 pVE => VE call DMComplexSetCone(dm, 7 , pVE, ierr) CHKERRQ(ierr) VE(1) = 1 VE(2) = 3 pVE => VE call DMComplexSetCone(dm, 8 , pVE, ierr) CHKERRQ(ierr)
call DMComplexSymmetrize(dm,ierr) CHKERRQ(ierr) call DMComplexStratify(dm,ierr) CHKERRQ(ierr)
!Test Stuff
call DMComplexGetTransitiveClosure(dm,10,PETSC_TRUE,nClosure,ierr) !pClosure,ierr) CHKERRQ(ierr) write(*,*) nClosure write(*,*) pClosure
call DMDestroy(dm,ierr) CHKERRQ(ierr) call PetscFinalize(ierr) CHKERRQ(ierr) end
The output is: 10 0 6 0 7 0 8
and then there is an error in DMDestroy
[0]PETSC ERROR: --------------------- Error Message ------------------------------------ [0]PETSC ERROR: Object is in wrong state! [0]PETSC ERROR: Work array still checked out! [0]PETSC ERROR:
------------------------------------------------------------------------ [0]PETSC ERROR: Petsc Development HG revision: b6fe82991deee4a0d3f9a20654bc7750a6b1fe0f HG Date: Mon Aug 27 13:17:10 2012 -0500 [0]PETSC ERROR: See docs/changes/index.html for recent updates. [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting. [0]PETSC ERROR: See docs/index.html for manual pages. [0]PETSC ERROR:
------------------------------------------------------------------------ [0]PETSC ERROR: ./test on a arch-linu named Puget-101334 by user Tue Aug 28 15:31:06 2012 [0]PETSC ERROR: Libraries linked from /home/user/Desktop/LIBRARIES/petsc-dev/arch-linux2-cxx-debug/lib [0]PETSC ERROR: Configure run at Mon Aug 27 12:55:14 2012 [0]PETSC ERROR: Configure options --download-boost --download-chaco --download-ctetgen --download-f-blas-lapack --download-fiat --download-generator --download-metis --download-ml --download-mpich --download-parmetis --download-scientificpython --download-triangle --with-clanguage=cxx --with-dynamic-loading --with-shared-libraries --with-sieve PETSC_ARCH=arch-linux2-cxx-debug [0]PETSC ERROR:
------------------------------------------------------------------------ [0]PETSC ERROR: DMDestroy() line 234 in /home/user/Desktop/LIBRARIES/petsc-dev/src/dm/interface/dm.c application called MPI_Abort(MPI_COMM_WORLD, 73) - process 0 [unset]: aborting job: application called MPI_Abort(MPI_COMM_WORLD, 73) - process 0
Ideas?
-- Chris Eldred DOE Computational Science Graduate Fellow Graduate Student, Atmospheric Science, Colorado State University B.S. Applied Computational Physics, Carnegie Mellon University, 2009 [email protected]
-- What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead. -- Norbert Wiener
participants (1)
Chris Eldred
