Re: [petsc-dev] -info from just one process?
On Fri, Apr 23, 2021 at 2:57 AM Pierre Jolivet <[email protected]> wrote:
On 22 Apr 2021, at 7:45 PM, Barry Smith <[email protected]> wrote:
It would be straightforward to add an option to -info to output only from a particular MPI_COMM_WORLD global rank.
Maybe an extra :rank at the end of the info options?
Open 128k files is nuts.
It is what it is, I’ve made peace with the fact that I can’t expect any meaningful timings for large runs when this option is on.
I'm not talking about timings, I am talking about seeing where a code dies.
As a side note, one would expect that this kind of behavior is consistent across the library. But in fact, it isn’t. If you do something like -sub_ksp_view_pmat file with, for example, DD preconditioners, you end up with a single file with all local matrices scrambled in. It would be nice to have the same logic, i.e., file.%p, and be able to filter ranks that actually print to file like you suggest. These kind of options are less critical than -info so I can just insert them in the option database after initialization, if rank == view_this_rank PetscOptionsInsertString(), but doing that using command line arguments would be easier and more elegant, IMO.
Thanks, Pierre
Barry
On Apr 22, 2021, at 11:14 AM, Mark Adams <[email protected]> wrote:
OK, so -info out.%p would do what I asked. Alas, what I really need it to reduce the output with 128K processes. Thanks,
On Thu, Apr 22, 2021 at 11:54 AM Pierre Jolivet <[email protected]> wrote:
On 22 Apr 2021, at 5:33 PM, Jacob Faibussowitsch <[email protected]> wrote:
Not out of the box no. There is -info ::self which makes info only print from calls made on PETSC_COMM_SELF, but I don’t think that’s what you want. Best advice would be to print to a file and grep the file for any lines starting with the rank number you want.
There is no need for grep, IMHO, just do -info file and then open file.%p
Thanks, Pierre
Best regards,
Jacob Faibussowitsch (Jacob Fai - booss - oh - vitch)
On Apr 22, 2021, at 10:16, Mark Adams <[email protected]> wrote:
Can I make -info only print from one process? Mark
participants (1)
Mark Adams
